Adding Extruder February 10, 2016 08:56AM |
Re: Adding Extruder February 10, 2016 09:23AM |
Re: Adding Extruder February 10, 2016 10:22AM |
Re: Adding Extruder February 12, 2016 05:57AM |
Re: Adding Extruder February 12, 2016 01:19PM |
Re: Adding Extruder February 12, 2016 01:37PM |
Re: Adding Extruder February 15, 2016 08:41AM |
Re: Adding Extruder February 17, 2016 06:32AM |
Re: Adding Extruder February 18, 2016 08:32AM |
Re: Adding Extruder February 18, 2016 09:57AM |
Re: Adding Extruder February 18, 2016 11:36AM |
Re: Adding Extruder February 18, 2016 11:44AM |
Re: Adding Extruder February 24, 2016 01:16PM |
Re: Adding Extruder February 24, 2016 02:17PM |
Re: Adding Extruder February 25, 2016 07:49AM |
Fpex
Can you power the duet4x with a second supply?
Fpex
Re: Adding Extruder February 25, 2016 09:22AM |
Re: Adding Extruder February 25, 2016 09:26AM |
Re: Adding Extruder February 25, 2016 09:36AM |
Re: Adding Extruder March 16, 2016 10:24AM |
Re: Adding Extruder March 16, 2016 07:10PM |
Re: Adding Extruder March 17, 2016 05:26AM |
Re: Adding Extruder March 17, 2016 07:50AM |
Re: Adding Extruder March 17, 2016 09:18AM |
Re: Adding Extruder March 17, 2016 10:22AM |
Re: Adding Extruder March 20, 2016 05:03AM |
Re: Adding Extruder March 25, 2016 08:46AM |
Re: Adding Extruder March 25, 2016 06:07PM |
Re: Adding Extruder March 28, 2016 05:25AM |
dc42
I have just checked the DueX4 0.2a schematic and I can see the problem. The DueX4 0.2a does not make pin AD12 available on the expansion connector. However, it is available on the 2-way jumper block. So you need to move the proximity sensor modulation wire from pin 12 on the expansion connector to the 2-way jumper block - the pin that is not occupied by the VSSA flylead. Alternatively, use a height sensor like my mini differential IR one that doesn't need the modulation signal.
Re: Adding Extruder January 04, 2017 05:37AM |
