Need a set of Z Axis gears printed please February 10, 2016 12:09PM |
Re: Need a set of Z Axis gears printed please February 10, 2016 03:04PM |
Re: Need a set of Z Axis gears printed please February 10, 2016 03:33PM |
bartdietrich
I'll print you a set. If you allow some time for me to figure out why one of my extruders suddenly started skipping for no apparent reason from one day to the next... Could even do you the spring-loaded extruder. Got two of them and they're pretty neat.
Bart
Re: Need a set of Z Axis gears printed please February 11, 2016 02:06PM |
Re: Need a set of Z Axis gears printed please February 11, 2016 02:23PM |
Re: Need a set of Z Axis gears printed please February 15, 2016 03:51PM |
Re: Need a set of Z Axis gears printed please February 15, 2016 04:50PM |
Re: Need a set of Z Axis gears printed please February 15, 2016 05:58PM |
brlowe
Thanks for the update. Not to be picky but check the center holes to make sure they look good. The 2 sets I got locally had holed that made them unusable for me as the nut would not fit in one and the other was too small to fit over the motor shaft by a long shot. The outsides looked great. Maybe that is the norm for 3d printing and I'm just expecting too much.
Re: Need a set of Z Axis gears printed please February 15, 2016 09:01PM |
Re: Need a set of Z Axis gears printed please February 16, 2016 07:53AM |
brlowe
Re: Need a set of Z Axis gears printed please February 16, 2016 09:36AM |
Treito
First of all you will have to check if you printed the calibration piece and followed the instruction. Then you should get good results. If not you should check the mechanics of your printer. A mostly common problems are loose belts which can result in inaccurate printings. Also make sure that your nozzle is perfectly angled to the bed and that the bearing is running freely with full contact.
Re: Need a set of Z Axis gears printed please February 16, 2016 10:49AM |
bartdietrich
A particular set of slicing software settings will not work optimally for every object, and slightly different printed dimensions are obtained from different batches and colours of plastic.
Re: Need a set of Z Axis gears printed please February 16, 2016 11:12AM |
Re: Need a set of Z Axis gears printed please February 16, 2016 01:16PM |
Treito
I was talking about your comment regarding printing in ABS. If I should have gotten something wrong then I have to excuse myself, but I understood that you had some other small issues besides the curling of the edges.
Re: Need a set of Z Axis gears printed please February 16, 2016 04:31PM |
brlowe
Re: Need a set of Z Axis gears printed please February 16, 2016 10:04PM |
Re: Need a set of Z Axis gears printed please February 17, 2016 03:49PM |
Re: Need a set of Z Axis gears printed please February 17, 2016 05:26PM |
Re: Need a set of Z Axis gears printed please February 25, 2016 02:03PM |
Re: Need a set of Z Axis gears printed please February 27, 2016 12:58PM |
