Filement sensor possible?
Posted by Fpex
February 18, 2016 01:04PM
I just saw a Felix Pro 1 and I was nicely surprised by a couple of features: a sensor that pause printing when the filament ends and the head tilting for dual heads.
I was wondering if anybody here has ever made a sensor to pause the print when the filament ends on duet firmware. Could be nice!
----- Making the world smarter @ www.xetal.eu
----- Helping entrepreneurs @ www.fralke.com
Re: Filement sensor possible?
February 18, 2016 02:38PM
Would be a great feature for when filament breaks and stops extruding.
Another thing I've seen is a nozzle clean feature. Seen on the Lulzbot Taz mini
February 18, 2016 02:46PM
Handling a filament out sensor is on my list for improvements to both RRF and PanelDue.
February 19, 2016 12:54PM
Nice! That would be great.
February 20, 2016 01:58PM
Filament out would be great but even better would be a rotatable sensor that could feel if the extruded length was correct.
February 21, 2016 02:58AM
Joar107
Or filament slipping...
February 21, 2016 10:46PM
Do someone have any information how this sensor works? i found some solutions but no concrete information of the principle. One seems to use a photosensitive switch (this would be also my idea), one uses some sort of hall sensor and I have no clue how this could work and the last one some sort of ball-bearing, perhaps like the spring-loaded Extruder itself and this (modified) solution would be the best option to add a rotary sensor.
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
February 22, 2016 07:07AM
Ideally a sensor should sense when the filament has stopped feeding, which is a bigger design challenge than merely sensing when it has run out. The filament can stop feeding if it breaks in the extruder or starts slipping for some reason (clogged feeder, blocked nozzle etc.).
Dave
February 22, 2016 08:46AM
Could be done is the filament were marked or by making a proper rotating filament spindle.
February 22, 2016 10:32AM
Yes, either a wheel in contact with the filament before it enters the extruder, or you could even put a sensor on the spool holder to detect the periodic rotation of the filament spool. Obviously either method would need a timeout so that a false output is not generated during non-printing moves (and a longer timeout needed in the case of a spool sensor as this tends to unwind in jerks with long periods of inactivity).
If modifying the firmware to allow the use of a "filament out" input, it would therefore be advantageous to incorporate a user-defined timeout, and also allow for the sensor to be one that toggles periodically when the filament is OK rather that having a defined state for filament out - in that way the movement sensor could be (e.g.) a rotary switch or reed switch & magnet which would remain in a constant "on" or "off" state when the filament stops moving but will toggle periodically when the filament is feeding.
Dave
February 22, 2016 11:57AM
I would be in four for the spool sensor (with timeout) as more reliable
February 22, 2016 12:05PM
dmould
...in that way the movement sensor could be (e.g.) a rotary switch or reed switch & magnet which would remain in a constant "on" or "off" state when the filament stops moving but will toggle periodically when the filament is feeding.
I like the idea of something like a spring loaded arm that pinches the filament between a bearing and a rotary encoder with a wheel which could give feedback to the control board/firmware of if filament is moving, how much, etc? The arm could also engage/disengage a regular microswitch in case of nothing being pinched between the bearing and encoder.
I don know if this one would be suitable,
http://www.digikey.com/product-detail/en/C14D32P-B3/102-1914-ND/2037010
Edited 1 time(s). Last edit at 02/22/2016 12:10PM by FA-MAS.
February 22, 2016 02:36PM
I would use something like this, [monsterfil.com]
A element where the filament needs to go through and it is also used to check if it is stuck or not
February 23, 2016 07:08AM
Fpex
AFAICS that does not detect a break or stoppage of the filament, it only checks for filament that is stuck on the reel (e.g. tangled).
From the advert: "... buzzer that alerts the user when the filament is not flowing during unspooling" (my emphasis added).
Dave
February 23, 2016 08:30AM
Mmmm
There must be a way to use spool movement and filament movement to detect a problem. Not sure we can point out what it is. But to know of a probe;em is already something
Edited 1 time(s). Last edit at 02/23/2016 08:40AM by Fpex.
February 26, 2016 08:40PM
I made a filament movement sensor for my Openbeam CoreXY Bowden extruder printer.
[forums.reprap.org]
Picked up that I was trying to extrude too much filament on my first layer which was giving an error, I found I had a slicer setting set wrong for the amount that of filament for first layer..
Pleased with how its working.
Cheers bruce
May 29, 2018 02:30PM
Hello,
Any success with the Duet3D filament sensor?
Link
Thanks
May 31, 2018 08:13AM
I have designed an optical sensor similar to that used in the MK3 Prusa.
I am still testing it, but it is looking very promising. I should be able to not only detect movement, but also determine colour and material type eventually also.
Mine is based on the Avago APDS-9960.
May 31, 2018 08:19AM
July 25, 2018 02:51PM
Sounds interesting. Can I join in the testing? smiling smiley
I preferred Hall-effect angle sensors because they remain reliable under all environmental conditions.
But I wouldn't exclude any solution that can save my prints with stuck filament. smiling smiley
July 25, 2018 06:51PM
We are currently testing a pre-production batch of laser filament sensors, see [forum.duet3d.com].
