I made a belt driven/feeding extruder
Posted by fotomas
Re: I made a belt driven/feeding extruder
March 22, 2016 05:20AM
As far as I know there are two versions of NinjaFlex available with different flexibility. Maybe the one with less flexibility would be more suitable for this job. At the moment I have no good working printer and also only bearings with an outer diameter of 9mm instead of 8mm. Otherwise I would have joined the test with my TPU filament from SainSmart.
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
March 22, 2016 05:46AM
The design stops me from changing the inner diameter for the roller to 9 mm. Otherwise I would have done that for you.
The roller gets to thin with five mm and a thicker/bigger roller would not fit without modifying the position of the rollers.
The TPU I am testing with I have forgotten the brand of but I have a roll of Torwell TPE that is a bit stiffer but harder to get to stick to the bed. When I have a design and printing method that works I will try that filament. It is easier to fix one problem at the time...
March 22, 2016 06:13AM
It's not recommended to fix more than one problem at a time. I ordered 30 pieces of 693ZZ bearings in total, but they will arrive in about 3 weeks.
March 22, 2016 08:11AM
You could try greater retraction length, and also try putting a column either side of and very close to the belt on the build plate so that the layer changes occur on the columns rather than the belt.
Dave
March 22, 2016 08:46AM
ok, but is there a way to make slic3r (I slice with slic3r) to change layer at the column?
March 22, 2016 08:54AM
Here is a picture of what it looks like. One can see that the belt looks pretty good except for the problem with the extra extrution at layer change.
March 22, 2016 09:52AM
fotomas
If you put the columns outside the belt and exactly opposite the midpoint in X or Y, you'll find that Slicer will print each column alternately last.
Dave
April 10, 2016 12:02PM
I have made one of these ,and seems to work but i got a few lines where there was sparese layer or something( it could be from overcooling i am not sure, i'll have to retry it)
Edited 3 time(s). Last edit at 04/10/2016 03:37PM by Darathy.
April 12, 2016 02:15PM
Wow great to se that it works for you. It brings me great joy that you went through the effort to make one.
My guess is that for some reason at that point in the print the resistance for pushing the filament through the nozze got tio great for the tourqe that the extruder can deliver.
As you are saying it could be cooling and\or the shaoe of the print.
I havet also hade the exact same phenomen in som of my prints.
I would recomend slower and hotter prints and maybe higher current to the stepper motor. What do you have it set to now?
The lack of torque seems to be the weak spot for this design. Do you have any ideas for improvements?
Edited 1 time(s). Last edit at 04/12/2016 02:16PM by fotomas.
April 12, 2016 02:42PM
I dont know i suspect my E3D nozzle is getting blocked somehow ,but i will have to try with my original extruder.
I have set the current to 1200 as you susggested, but it does start to skip steps sometimes and then skips all time when i tried to print 3Dbenchy and ruined the print but as said before it somehow gets cloged or something.
April 12, 2018 01:59PM
Hey,
Thanks for the design.
Originally I printed the frame in PLA but due to the heat of my stepper motor the frame soon distorted. I managed to print in ABS and it was alot stronger.
More often now I see that the filament is getting kinked and it stops extruding (please see attached photo)
Do you know of any way to combat this issue?
