Hi this is my first time posting here so I will give my printer info and then state my question
Printer:
Folger Tech 2020 delta printer with inductive auto-leveling probe
So everything seems to be working fine except the probe. Its not that it doesn't work at all but i am not getting accurate distance readings. There are highs and lows through out movement that creates a surface(Virtual) that is not parallel with the plate(Aluminium) This wouldnt be too big of problems if it wasn't off by so much. It is off my a couple mm enough to make deformities in the prints in the probed high areas. I will attach my code if you need that as well.
If there is any other question please post below and I will answer in a timely manor
Thanks in advance, Sage
