Spare parts April 04, 2016 05:19AM |
Re: Spare parts April 04, 2016 05:58AM |
Re: Spare parts May 09, 2016 06:50PM |
Re: Spare parts May 09, 2016 07:17PM |
Re: Spare parts May 09, 2016 10:20PM |
Re: Spare parts May 10, 2016 06:41AM |
dc42
I see no reason why you can't print the fan spacer, although if the second fan hangs off it then I guess it might bend eventually with the load and the heat. You should be able to find the DXF file for it in RRP's github repo, then use a modelling program such as OpenScad to turn it into an STL with a defined thickness.
The second fan should be connected to the FAN0 output of the Duet, so that it is turned off when printing the first layer or when printing ABS.
Re: Spare parts May 11, 2016 04:21AM |
Re: Spare parts May 12, 2016 06:23PM |
