Help with commissioning new Ormerod 2 April 18, 2016 06:37PM |
Re: Help with commissioning new Ormerod 2 April 18, 2016 09:58PM |
Re: Help with commissioning new Ormerod 2 April 18, 2016 10:05PM |
Re: Help with commissioning new Ormerod 2 April 18, 2016 10:41PM |
Re: Help with commissioning new Ormerod 2 April 18, 2016 11:26PM |
Re: Help with commissioning new Ormerod 2 April 19, 2016 12:06AM |
0x0000
Looks like your M305 commands in that screenshot have semicolons at the start of the line. Everything to the right of a semicolon is ignored (known as a comment). Remove those semicolons and try again
Re: Help with commissioning new Ormerod 2 April 19, 2016 01:53AM |
Re: Help with commissioning new Ormerod 2 April 19, 2016 02:39AM |
Re: Help with commissioning new Ormerod 2 April 19, 2016 11:02AM |
dc42
Perhaps your config.g file is not being read at startup. Try sending M563 P0 D0 H1 from Pronterface and see if you get a hot end temperature reading.
If you are still running the RRP 1.09 firmware release, upgrade to my or chrishamm's latest. There was a formatting error in the M105 response in 1.09 that confused Pronterface AFAIR.
Also try to get the web interface working, it's easier to use than Pronterface.
Re: Help with commissioning new Ormerod 2 April 19, 2016 05:04PM |
Re: Help with commissioning new Ormerod 2 April 19, 2016 05:29PM |
Re: Help with commissioning new Ormerod 2 April 19, 2016 06:51PM |
dc42
The USB manufacturer string has changed between version 1.10+4 and 1.11, which probably has something to do with why you can't connect to 1.11; but this is the first time I've heard of failure to connect to it using the Arduino Due driver. Can you tell me which operating system you run on your PC, and which version of Arduino you have installed?
Re: Help with commissioning new Ormerod 2 April 19, 2016 07:02PM |
Re: Help with commissioning new Ormerod 2 April 20, 2016 08:21AM |
brlowe
I am running windows 8.1 and Arduino 1.6.7.
Is there a driver I can download and install or anything that might help it connect?
Re: Help with commissioning new Ormerod 2 April 20, 2016 01:30PM |
dc42
brlowe
If/when you feel like trying again, please try the following:
- Right click the device in Device Manager and select "Update driver"
- Select "Browse my computer for driver software"
- Select "Let me pick from a list of device drivers on my computer"
- If "USB Serial Device" (without the word "Modem") is not listed, uncheck "Show compatible hardware" and under Manufacturer select Microsoft
- Select "USB Serial Device"
Re: Help with commissioning new Ormerod 2 April 20, 2016 04:25PM |
