Hot End temperature fault error. May 15, 2016 10:39AM |
Re: Hot End temperature fault error. May 15, 2016 11:34AM |
Re: Hot End temperature fault error. May 15, 2016 12:12PM |
Europa
Adding to the above post the M305 line in my config file is:
M305 P1 R4700 B4267
The printer is an Ormerod 2
The fault occurs at the higher temperatures when I am printing with ABS, it is less of a problem when printing with PLA
Temperature I am using for ABS is 235 degrees.
Many thanks,
Brian
Re: Hot End temperature fault error. May 15, 2016 12:18PM |
Re: Hot End temperature fault error. May 15, 2016 04:54PM |
Re: Hot End temperature fault error. May 16, 2016 03:22AM |
Re: Hot End temperature fault error. May 16, 2016 10:46AM |
Re: Hot End temperature fault error. May 16, 2016 11:03AM |
PRZ
[edit] If final reaching setpoint is slow, you have to adjust PID.
For heating adjustment, have a look at this RepRap wiki page 'RepRap_Firmware_heating': [reprap.org]
In M301, don't forget the T parameter, it is specific to RepRap Firmware DC42 fork, but it improves the control and I get much better result with the Fisher hotend while adjusting it (which is relatively easy).
I have not looked the firmware code (not capable to), but I assume this T parameter remove the constant heating power from the PID controlled power, then add it back. David may confirm the philosophy behind.
Re: Hot End temperature fault error. May 16, 2016 01:52PM |
Re: Hot End temperature fault error. May 16, 2016 03:33PM |
Europa
Hi guys, I have increased the B value from 4267 to 4388 as suggested but the last 5 degrees, from 235 to 240 are taking around 5 minutes.
Should I also have a go at increasing the S value ?
Thanks,
Brian
Re: Hot End temperature fault error. May 18, 2016 02:32PM |
Re: Hot End temperature fault error. May 18, 2016 03:20PM |
Europa
By the way, I have been thinking of buying one of your Mini Differential IR height sensors. Can I simply connect it to the original plug for the sensor as shipped with the Ormerod 2 or does it need to connect to different pins on the Duet?
Does it have to fit in front of the E3D V6 hotend or can it be mounted on the side where the original sensor sits?
Re: Hot End temperature fault error. May 18, 2016 03:56PM |
Re: Hot End temperature fault error. May 18, 2016 06:01PM |
Europa
Hi Dave,
When you say in line with the nozzle in the X axis that would effectively put the sensor to the left of the nozzle when viewed from the cooling fan which is blowing in the Y direction ?
I would need to design a new mount for the hot end but that is not a problem.
Can I order from your site Escher 3D ?
