Bed Compensation ruins first layer June 08, 2016 01:20PM |
Re: Bed Compensation ruins first layer June 08, 2016 01:44PM |
Re: Bed Compensation ruins first layer June 09, 2016 09:26AM |
Re: Bed Compensation ruins first layer June 09, 2016 04:06PM |
Re: Bed Compensation ruins first layer June 10, 2016 02:02AM |
Re: Bed Compensation ruins first layer June 10, 2016 03:33AM |
Re: Bed Compensation ruins first layer June 10, 2016 09:58PM |
Re: Bed Compensation ruins first layer June 10, 2016 10:28PM |
Re: Bed Compensation ruins first layer June 11, 2016 05:21AM |
RoboPicker
Hey Guys,
Exactly the same issue here. I've leveled the bed and can print well without auto bed leveling. However once I turn on the 5 point leveling things get pretty bad, can see the Z axis winding up and down even though I know the bed is flat.
Is anyone else here using this function with success? Using the upgraded differential IR sensor and version 1.13b btw.
Re: Bed Compensation ruins first layer June 11, 2016 05:23PM |
Re: Bed Compensation ruins first layer June 11, 2016 06:02PM |
Re: Bed Compensation ruins first layer June 12, 2016 07:01PM |
Re: Bed Compensation ruins first layer June 13, 2016 07:47AM |
Re: Bed Compensation ruins first layer June 13, 2016 08:06AM |
Re: Bed Compensation ruins first layer June 13, 2016 10:29AM |
Treito
Originally my Ormerod 1 had a height difference of more than 1mm which I wasn't able to remove. Why I am telling this? To make you one thing clear: If you put such a feature into your firmware the dimensions will not be accurate.
Re: Bed Compensation ruins first layer June 13, 2016 11:43AM |
Re: Bed Compensation ruins first layer June 14, 2016 07:02AM |
Treito
Why not?
Re: Bed Compensation ruins first layer June 14, 2016 08:19AM |
