I tried to print an item from the SD card, but whenever I went to browse for the file I would get "an AJAX error has occurred" which would reset the connection.
I really needed to print the file, so I used gcodes to print the file directly.
The print went perfectly, but the web interface did not work at at all - kept on throwing up JSON errors.
I turned on the developer view in Firefox and captured this error:
Error! The following JSON response could not be parsed:
model.js:993 {"err":0,"size":2465816,"height":0.00,"firstLayerHeight":0.20,"layerHeight":0.20,"filament":[8355.8],"generatedBy":"Slic3r 1.30.0-prusa3d-release_candidate_1_3 on 20","printDuration":5817,"fileName":"DAVID\UPPERNEW.GCODE"}
I was wondering if it might have something to do with the \U, but I don't know anything about web development, so could be talking total junk!
It's not using the latest firmware, so it might already be solved?
Edited 1 time(s). Last edit at 08/02/2016 07:50AM by VortyZA.
