ABS Settings? August 18, 2016 04:18PM |
Re: ABS Settings? August 18, 2016 08:37PM |
Re: ABS Settings? August 19, 2016 04:24AM |
Re: ABS Settings? August 19, 2016 05:42AM |
ayudtee
Hi Pointy,
The settings that I use are 100 deg bed and 230 deg hotend. I am using a 4 mil kapton sheet on the glass bed, which is much sturdier than the kapton tape that came with my Ormerod 2. I clean it with acetone and use nothing else and get good adhesion.
The first time I printed with abs the hotend fell off of the carriage, as the pla nozzle mount is not able to handle the abs temperature too long. I highly recommend that the first abs print that you attempt is a new nozzle mount, then you should be good to go. Good luck
Re: ABS Settings? August 19, 2016 09:12AM |
Re: ABS Settings? August 19, 2016 04:55PM |
Re: ABS Settings? August 19, 2016 05:16PM |
Re: ABS Settings? August 19, 2016 05:17PM |
Re: ABS Settings? August 19, 2016 06:12PM |
Darathy
If you have some acetone ,put some in a flask and mix in some of the ABS fillament(the failed part will work aswell) making ABS slurry ,you can apply that to the heated bed with a paint brush in a thin layer. It will help it not to warp. As for brittle try increasing temperature to 235 or 240.
dc42
You may need higher temperature than 230C, or perhaps you have some unwanted print cooling. Is it an Ormerod 1? If so, did you block off the air escape vents at the bottom of the fan duct, and drill an escape chimney at the top to let the air out instead?
Re: ABS Settings? August 20, 2016 02:43AM |
Re: ABS Settings? August 20, 2016 04:26PM |
achaz
except in very limited scenarios this is very undesirable with ABS. Will cause terrible layer bonding and the result will be a very brittle partQuote
Pointy
If this is undesirable for ABS, I will look at how I can block/vent the airflow.
