Heat Bed default September 12, 2016 05:37AM |
Re: Heat Bed default September 12, 2016 10:52AM |
Re: Heat Bed default September 12, 2016 11:17AM |
Re: Heat Bed default September 13, 2016 05:01AM |
mat_fr
Now for the latest problem: I tried to print a piece in ABS, and the heat bed stopped heating after a layer. The temperature just drops as the webpage indicates "default" under the bed. It is an intermittent failure but once it occurs the firmware doesn't try again. The thermistor contact doesn't seem to be the root cause because the message is: "Error: heating fault on heater 0, temperature rising much more slowly than the expected 0.0°C/sec"
What in your opinion could be the problem?
Re: Heat Bed default September 13, 2016 05:24AM |
Re: Heat Bed default September 13, 2016 06:19AM |
Re: Heat Bed default September 13, 2016 06:26AM |
Re: Heat Bed default September 13, 2016 07:05AM |
mat_fr
It can reach 105 if I let him enough time (like 30mn or so, I never measured but it seems endless)..
Re: Heat Bed default September 13, 2016 07:47AM |
mat_fr
Thanks for the link also. Are these rubber heat beds easily installed on the Ormerod ? Sorry the question is naive but the stock ormerod2 is my only experience with 3D printer and I find it very delicate to handle so I've become very cautious about touching it (less and less, that being said )
Re: Heat Bed default September 13, 2016 07:55AM |
Re: Heat Bed default September 13, 2016 10:59AM |
Re: Heat Bed default September 13, 2016 12:14PM |
Re: Heat Bed default September 13, 2016 12:30PM |
Re: Heat Bed default September 13, 2016 12:39PM |
Re: Heat Bed default September 13, 2016 12:46PM |
Re: Heat Bed default September 13, 2016 02:05PM |
Re: Heat Bed default September 14, 2016 02:43AM |
Re: Heat Bed default September 14, 2016 06:12AM |
Re: Heat Bed default September 14, 2016 07:00AM |
Re: Heat Bed default September 14, 2016 07:47AM |
Re: Heat Bed default September 14, 2016 08:47AM |
Re: Heat Bed default September 14, 2016 03:24PM |
Re: Heat Bed default September 15, 2016 07:27AM |
Re: Heat Bed default September 15, 2016 07:48AM |
Re: Heat Bed default September 17, 2016 08:58AM |
dmould
I have found that if you leave residual plastic cooking in the hotend without extruding for longer than a minute or two, you'll get a blocked nozzle soon afterwards, so be quick with the temperature measurement and never leave the hotend at temperature for long before extruding. Using a drill to unblock will work, but it may have scratched the walls of the hole and/or liner which will reduce the quality of the extrusion and also left brass or PTFE debris that will cause another blockage soon, so maybe buy a few spare nozzles (with some PTFE tube for the liner) while you are at it.
Re: Heat Bed default September 19, 2016 12:56PM |
Re: Heat Bed default September 20, 2016 02:26AM |
Re: Heat Bed default September 20, 2016 08:34AM |
Re: Heat Bed default September 21, 2016 03:13AM |
Re: Heat Bed default September 21, 2016 06:55AM |
mat_fr
I had printed this spool holder [www.thingiverse.com] but when the spool is too light it doesn't "stick", it gets off of the spool.
