Printer does dots instead a circle December 02, 2016 11:51AM |
Re: Printer does dots instead a circle December 02, 2016 03:06PM |
Re: Printer does dots instead a circle December 02, 2016 03:47PM |
Re: Printer does dots instead a circle December 02, 2016 04:23PM |
Re: Printer does dots instead a circle December 02, 2016 04:39PM |
lockezio
Do you mean that it prints the dots then prints the heart shape over top of them. If it's the first, then it's just the way slicers interpret the models, tiny gaps in circular shapes that sometimes get filled during perimeters and some times skipped. Since the slicers break the circles into lines rather than arcs.
Re: Printer does dots instead a circle December 02, 2016 04:45PM |
Re: Printer does dots instead a circle December 03, 2016 12:35PM |
Re: Printer does dots instead a circle December 03, 2016 04:07PM |
Re: Printer does dots instead a circle December 05, 2016 07:33AM |
Re: Printer does dots instead a circle December 14, 2016 08:18AM |
dmould
It is almost certainly to do with wall thickness and extrusion thickness. I don't recall whether you can alter the extrusion thickness in Cura (this is NOT the same as nozzle diameter). If you change the perimeter extrusion thickness OR the wall thickness of the heart a little (0.1mm or less is probably enough), you should see the issue disappear.
Dave
