Webinterface request
Posted by Darathy
December 13, 2016 01:31PM
I have version 1.12 and i am highly annoyed by the stacking notifications since they cover the move buttons after i press one 4 times... and was wondering is there anywhere i can disable them? i have looked and i cant find anything related to it.
Edited 2 time(s). Last edit at 12/13/2016 01:32PM by Darathy.
Re: Webinterface request
December 13, 2016 05:43PM
They time out automatically in version 1.13.
December 14, 2016 03:03PM
Ok i have updated to 1.13 and i'm still geting them over the move buttons. You must have missunderstood me . I mean can it be made so only 2 are active at time? more then 2 the first would go away instantly. becouse when i press for example Y+10 for 5 times they stack over the buttons when i wanted to go 6 times over and i cant click on the button anymore.
Edited 1 time(s). Last edit at 12/14/2016 03:10PM by Darathy.
December 14, 2016 04:58PM
What are you doing that is causing so many messages to be generated?
December 14, 2016 05:27PM
I was trying to adjust my auto bed compensation the H parameter in Bed.g file ,so i was using it to jog to corners and see how much diference there was till nozzle would grip the paper ,guess i could just use simple Gcode to get there. Guess its not a big deal ,since i rarely use it but when i do it annoys me atleast.
Edited 1 time(s). Last edit at 12/14/2016 05:27PM by Darathy.
December 15, 2016 02:17AM
I am asking in case there is a firmware bug to be fixed. You appear to be using M120 commands, which is unusual. I guess you have written some macro files. Can you share them? Also, which firmware version are you running?
Edited 2 time(s). Last edit at 12/15/2016 02:18AM by dc42.
December 15, 2016 04:19AM
Im not using any other then the ones that were on your github for sd card files. M120 is from the jog buttons.
December 15, 2016 05:28PM
Something is wrong because using the jog buttons shouldn't cause the commands to be echoed, which is what appears to be happening. Please post your config.g file. Which firmware version are you using?
Edited 1 time(s). Last edit at 12/15/2016 05:30PM by dc42.
December 16, 2016 01:16PM
i was runing 1.15e updated to 1.16 still same as before. Attached the config file.
open | download - config.g (3.1 KB)
December 16, 2016 02:29PM
Sorry, I haven't yet found any way to view .g files as text files on an Android tablet (suggestions welcome!). I'll look at it tomorrow assuming I remember.
December 16, 2016 02:40PM
r; Ormerod 2 config file for dc42 Duet firmware
M111 S0                             ; Debug off
M550 PMy Ormerod			        ; Machine name (can be anything you like)
M551 Preprap                        ; Machine password (currently not used)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
;*** Adjust the IP address and gateway in the following 2 lines to suit your network
M552 P192.168.178.240                 ; IP address
M554 P192.168.178.1                   ; Gateway
M553 P255.255.255.0                 ; Netmask
M555 P2                             ; Set output to look like Marlin
G21                                 ; Work in millimetres
G90                                 ; Send absolute coordinates...
M83                                 ; ...but relative extruder moves
M574 X0 Y1 Z0 S1					; set endstop configuration (Y endstop only, at low end, active high)
M906 X1100 Y1100 Z800 E1100           ; Set motor currents (mA)
M563 P0 D0 H1                       ; Define tool 0
G10 P0 S0 R0                        ; Set tool 0 operating and standby temperatures
M92 E420                        	; Set extruder steps per mm (single nozzle)
;*** If you have a dual-nozzle build, remove or comment out the previous line, and un-comment the following 3 lines
;M563 P1 D1 H2                      ; Define tool 1
;G10 P1 S0 R0                       ; Set tool 1 operating and standby temperatures
;M92 E420:420						; Set extruder steps/mm (dual nozzle)
;*** If you have a modulated IR probe with on-board microcontroller, change P2 to P1 in the following
M558 P1 H2                            ; Use a simple modulated Z probe (change to P1 for an intelligent Z probe)
G31 Z2 P500                      ; Set the probe height and threshold (put your own values here)
;*** If you have a Duet board with 4.7K thermistor series resistors, change R1000 to R4700 to the following M305 commands
M305 P0 R4700 H0 L0					; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 R4700 H0 L0  					; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 R4700 H0 L0					; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the IR sensor
M557 P0 X50 Y25                      ; Four...
M557 P1 X50 Y195                    ; ...probe points...
M557 P2 X200 Y195                   ; ...for bed...
M557 P3 X200 Y25                     ; ...levelling
M557 P4 X120 Y104                 ; 5th probe point for levelling (un-comment this if you are using a dc42 differential IR probe)
;*** if you are using axis compensation, put the figures in the following command
M556 S74 X0.0 Y0.3 Z0.5                   ; Axis compensation here
M201 X800 Y800 Z15 E1000            ; Accelerations (mm/s^2)
M203 X15000 Y15000 Z100 E3600       ; Maximum speeds (mm/min)
M566 X600 Y600 Z30 E20              ; Minimum speeds mm/minute
M208 X200 Y209	Z180					; set axis maxima (adjust to suit your machine)
M208 X0 Y0 S1						; set axis minimum (adjust to make X=0 the edge of the bed)
;M92 X87.49 Y87.49
M572 D0 S0.2
December 17, 2016 04:13AM
The only thing I can see wrong with that is the "r" character at the very start of the file, assuming you pasted the file contents correctly. I don't think it should prevent the firmware from reading the following M111 S0 command to turn debug off, but I guess it might. Try sending M111 S0 manually anyway, then use the jog controls and see if the messages have stopped.
December 17, 2016 05:18AM
David
Try Droidedit it allows me to open them ok (May have to download the file first mind or put it in Dropbox or similar)
Doug
December 17, 2016 09:12AM
I removed the "r" in the begining ,it still does M120 ,i also tried sending M111 S0 manualy with same result. While i have your attention if i use Software reset gcode(M999 or Emergency stop) it will not reconnect to the firmware till i turn my ormerod off and on again.
January 16, 2017 11:25AM
So much confusion about one checkbox smiling smiley Go to Settings -> User Interface and disable "Log any successful G-code". That should prevent the notifications from popping up when you press a button on the web interface.
Maybe it's time to refine this behaviour a bit in my next web interface version.
