Terminal connector melted
Posted by wado80
December 29, 2016 10:17AM
Hi
My terminal connector melted on my duet board due to loose screw.
So i wonder if I can solder the cables direct to the board and what cable to use to replace the one supplied with the Ormerod 1?
Re: Terminal connector melted
December 29, 2016 01:09PM
You can either solder the cables direct to the board, or replace the terminal block. If you are in the UK, this one [www.maplin.co.uk] should be suitable
Here [www.maplin.co.uk] is an example of suitable cable. They also sell a 20A version, but only on the web site, not in their stores. Another option is heavy-duty speaker cabling.
December 29, 2016 02:16PM
Thank you for the links. Unfortunately I live in sweden so can“t order from there, but now i know what to look for.
