Diryt och scratched Nozzle? January 03, 2017 05:40AM |
Re: Diryt och scratched Nozzle? January 03, 2017 06:38AM |
http://hydraraptor.blogspot.se/2014/07/pla-pipe-cleaner.html
So to recap:
Heat to extrusion temperature and pull out the filament being used.
Use a 0.4mm drill shank to clear the aperture.
Insert PLA (preferably natural so you can see the contamination) and flush through the remaining original filament. You may need to keep clearing the aperture with the drill shank.
Cool the extruder to 80°C with the drill shank in place to ensure the nozzle is clear.
Remove the drill and then pull out the PLA.
Inspect the end that comes out to see the culprit contamination.
Re: Diryt och scratched Nozzle? January 03, 2017 08:43AM |
