How to correct Y-axis twist January 06, 2017 11:07AM |
Re: How to correct Y-axis twist January 06, 2017 11:54AM |
Re: How to correct Y-axis twist January 06, 2017 05:05PM |
bitfield
Maybe I should give this a try? The Dropbox links gives 404 though.
[forums.reprap.org]
Re: How to correct Y-axis twist January 09, 2017 06:15AM |
Re: How to correct Y-axis twist January 09, 2017 07:39AM |
VortyZA
If the twist is on the motor side, you would need to remove the motor and belt to get to the screws.
Re: How to correct Y-axis twist January 09, 2017 09:06AM |
Re: How to correct Y-axis twist January 09, 2017 03:14PM |
Re: How to correct Y-axis twist January 10, 2017 01:57AM |
Re: How to correct Y-axis twist January 10, 2017 02:08AM |
Re: How to correct Y-axis twist January 10, 2017 11:09AM |
Re: How to correct Y-axis twist January 10, 2017 11:57AM |
Re: How to correct Y-axis twist January 11, 2017 01:45AM |
dmould
VortyZA
It doesn't matter which side the misalignment is, it can always be corrected by twisting the non-motor side only. The goal is to get the Y rods exactly parallel, you can then raise or lower the front of the bed to get it level.
Dave
Re: How to correct Y-axis twist January 11, 2017 01:50AM |
Re: How to correct Y-axis twist January 11, 2017 02:11AM |
VortyZA
Darathy
Dont think its a mirror ,the distance betweetn rods is slightly different i think.
It's not unfortunately a mirror. The Ormerod 1 is 80mm horizontally, 12 vertically between the centers of the rods, while the Ormerod 2 is 78mm horizontally (measured from the DXF files)
Re: How to correct Y-axis twist January 27, 2017 01:22AM |
Re: How to correct Y-axis twist January 27, 2017 07:20AM |
That looks great, although I noticed that the "Y idler adjustment ring" is not included. This is just a thumb wheel to fit the bolt head, so is easy enough to design.
Re: How to correct Y-axis twist January 27, 2017 07:27AM |
Re: How to correct Y-axis twist February 01, 2017 11:54AM |
Re: How to correct Y-axis twist February 08, 2017 01:07PM |
