Cant connect to Ormerod at all April 03, 2017 11:38AM |
Re: Cant connect to web interface April 03, 2017 12:19PM |
Re: Cant connect to web interface April 03, 2017 12:26PM |
dc42
Which firmware version are you using? Do the LEDs on the Ethernet connector light up when you plug in the LAN cable?
Re: Cant connect to web interface April 03, 2017 03:55PM |
Sardi
As I keep the "Network and sharing center" window open, and then press the "reset" button on the duet board - nothing happens. It usually breaks/resets the lan connection, and I see in the "Network and sharing center" how a new connection is being set up, but now, Its as I didnt press anything, it just stays connected.
Re: Cant connect to web interface April 03, 2017 04:03PM |
Re: Cant connect to web interface April 03, 2017 04:18PM |
Re: Cant connect to web interface April 03, 2017 04:43PM |
dc42
You can find the IP address by sending M552 from USB or PanelDue.
Re: Cant connect to web interface April 03, 2017 05:05PM |
Re: Cant connect to web interface April 03, 2017 05:41PM |
Re: Cant connect to web interface April 04, 2017 04:51AM |
Re: Cant connect to Ormerod at all April 04, 2017 05:59AM |
Re: Cant connect to Ormerod at all April 04, 2017 07:09AM |
Re: Cant connect to Ormerod at all April 11, 2017 12:22PM |
Re: Cant connect to Ormerod at all April 11, 2017 12:38PM |
Re: Cant connect to Ormerod at all April 12, 2017 10:24AM |
Re: Cant connect to Ormerod at all April 15, 2017 09:28AM |
Re: Cant connect to Ormerod at all May 02, 2017 09:45AM |
Re: Cant connect to Ormerod at all May 02, 2017 03:42PM |
Re: Cant connect to Ormerod at all May 02, 2017 04:47PM |
Re: Cant connect to Ormerod at all May 02, 2017 07:32PM |
Sardi
You printed something AFTER the smell of burning electronics?
Re: Cant connect to Ormerod at all May 02, 2017 07:33PM |
dc42
L7 has nothing to do with the Ethernet port. L7 connects analog ground to digital ground. It will burn out if you get a short between 12V and the ground side of any thermistor. Sadly, such shorts appear to be quite common.
Re: Cant connect to Ormerod at all May 03, 2017 04:28PM |
