hotend acting cloggy July 20, 2017 11:31AM |
Re: hotend acting cloggy July 21, 2017 07:15AM |
Re: hotend acting cloggy July 21, 2017 07:50AM |
Re: hotend acting cloggy July 22, 2017 09:02AM |
Re: hotend acting cloggy July 24, 2017 04:40AM |
Re: hotend acting cloggy July 24, 2017 06:50AM |
Re: hotend acting cloggy July 24, 2017 09:27AM |
Re: hotend acting cloggy July 24, 2017 09:31AM |
Re: hotend acting cloggy July 24, 2017 10:23AM |
Re: hotend acting cloggy July 24, 2017 01:05PM |
Re: hotend acting cloggy July 24, 2017 01:29PM |
Re: hotend acting cloggy July 24, 2017 01:36PM |
Re: hotend acting cloggy July 24, 2017 01:39PM |
Could you first layer be too low?
do the hotend swing freely around the smooth rod?
any extra weight added to the hotend recently?
what happens if you set first layer zero
is the push form extruder able lift the nozzle?
M556 S77 X0.15 Y0.5 Z0.6
Look like its kind of repeating in length of filament, anything strange with the big extruder gear?
Re: hotend acting cloggy July 24, 2017 01:43PM |
Re: hotend acting cloggy July 25, 2017 03:50AM |
redblunt
First layer ist set to 0.3mm as all layers.
Hotend can swing about 3mm up.
No extra weight.
You mean in the slic3r setting? Did not try that
Dont think so but i actually did not try with this hotend.
As I remember the original hotend was not able to.
Might my axis compensation be to high?
Because on the picture the problem zones quite look
like beeing regularly:
Extruder gear got printed out couple weeks ago and looks normal to me also how it spins
when turning it really fast.
Re: hotend acting cloggy July 25, 2017 05:23AM |
Re: hotend acting cloggy July 25, 2017 05:46AM |
Re: hotend acting cloggy July 25, 2017 06:30AM |
Re: hotend acting cloggy July 25, 2017 07:34AM |
redblunt
The big gear side of the coldend is kinda slid out but I guess this is not the actual problem beacause
hobbed wheel does not seem to run very circular.
..so I might decrease distance between the hobbed wheel and the bearing
..or make the bearing thicker
..or try a new screw
Re: hotend acting cloggy July 25, 2017 03:19PM |
