Z Axis Direct Drive upgrade August 05, 2017 09:29AM |
Re: Z Axis Direct Drive upgrade August 07, 2017 08:30AM |
Re: Z Axis Direct Drive upgrade August 07, 2017 09:38AM |
dmould
I have done a similar mod to my Ormerod. Z backlash is not a problem because the weight of the X arm ensures that it is always pushing in one direction (down), so no matter how loose the nut, there is no backlash.
Dave
Re: Z Axis Direct Drive upgrade August 08, 2017 02:29PM |
Re: Z Axis Direct Drive upgrade August 09, 2017 09:40AM |
Re: Z Axis Direct Drive upgrade August 09, 2017 12:06PM |
dmould
AFAICS that part of the Ormerod is the same on both models, so I should think so.
Dave
Re: Z Axis Direct Drive upgrade August 09, 2017 05:10PM |
Sardi
dmould
Dave
Yeah, I thought so but wanted to be sure. I always thought direct drive would work better (or if anything - simpler) then the one with two gears.
There is also this option to convert the ormerod to a direct drive but it requires to modify the x rib in order to keep the z motor in the same place.
Re: Z Axis Direct Drive upgrade August 11, 2017 02:31AM |
trevmas
WARNING! The original Ormerod solution allowed the Z nut to pop free if you crashed the head into the bed. This solution means that is no longer the case, all you have is the small amount of lift allowed by the rotation of the head on the rail.
Re: Z Axis Direct Drive upgrade August 11, 2017 03:03PM |
Karoo Klong
trevmas
Can you not also wire in a conventional limit switch as a failsafe for if the carriage would crash into the bed?
By the way, great job on this upgrade!
