Z babystepping setup
Posted by Sardi
January 18, 2018 09:38AM
So how do I do it?
I see on the web interface I can move the nozzle 0.05 up/down, but the button is greyed out. The gcode wiki says to put M290 Snnn Amount to baby step in mm. Positive values raise the head, negative values lower it in the config.g but how will the head go down then?
Or must I put 2 x M290, one with positive value other with negative value?
I really have no idea grinning smiley
Edited 1 time(s). Last edit at 01/18/2018 10:25AM by Sardi.
Re: Z babystepping setup
January 18, 2018 11:26AM
If you are using firmware and web interface 1.19 or later, the babystepping controls will appear when you print a file from SD card.
January 18, 2018 11:39AM
Im still at firmware 1.17e/ web interface 1.15.
July 05, 2019 04:24AM
Sardi
Do yourself and your printer a favour and update to the latest firmware.
The auto mesh bed leveling is the most amazing update ever and makes great printing adhesive a reality!
Updates can also be done via the web interface now and no need for BOSSAC anymore
Great work DC42 and everyone else involved!
I only hope there was a way we could have the same web type interface for cnc machining.
I have started printing on my CNC machine about three weeks ago.
