6 way hot end connector - what is it?
Posted by WesBrooks
April 15, 2018 05:56PM
Looking for details on the connector that may help buy a pin removal tool!
Re: 6 way hot end connector - what is it?
April 15, 2018 06:00PM
...no worries, found it!
[forums.reprap.org]
[uk.rs-online.com]
July 25, 2018 01:18PM
I couldnt find the 6pin hotend plug anywhere in South Africa. sad smiley
July 25, 2018 06:49PM
[za.rs-online.com] ?
July 26, 2018 12:18AM
Swapping the plug with one with easily removable pins can't be a bad thing! Maybe a bit more chunky but doubt the extra weight is significant.
August 08, 2018 08:20AM
You have a good pint. The pins are more easily removable and are also has a higher current rating.
Also there is another two open slots for when I connect the part cooling fan.
Can the two fans runn off the same ground?
August 08, 2018 09:08AM
Karoo Klong
No, but they can share the +12V connection.
