Hi
I have just performed an update on a ormerod 1. I followed the instructions from cheeseandham up to the point of using the bossac command. As recommended, I copied the bossac program and the RepRap firmware to the same directory and used the commend:
./bossac -e -w -v -b RepRapFirmware-1.09.bin
Note that the bossac program needs to have read and write privillages for the port in question. I am running an old version of Fedora in which the ports are usually locked-down. I have to re-new the privillages for the port each time the system detects a change in the port's status - this includes resetting the duet board.
sudo chmod a+rw /dev/ttyACM0
Details may vary with your system, however, assuming you do not have other arduinos connected the bossac program should be able to find the correct port without further assistance. The IDE software recommended for the arduinos can be a useful in determining which /dev/ttyACM0 port the duet is connected to - note the number may change when the port status changes.
