HELP -----> Need slic3r config - Start/End G-Code September 16, 2018 02:16PM |
Re: HELP -----> Need slic3r config - Start/End G-Code September 18, 2018 12:11PM |
# generated by Slic3r 1.2.6 on Tue May 5 11:18:25 2015 [filament:ABS] bed_temperature = 100 bridge_fan_speed = 100 cooling = 1 disable_fan_first_layers = 3 extrusion_multiplier = 1 fan_always_on = 0 fan_below_layer_time = 20 filament_diameter = 1.75 first_layer_bed_temperature = 100 first_layer_temperature = 0 max_fan_speed = 100 min_fan_speed = 0 min_print_speed = 10 slowdown_below_layer_time = 20 temperature = 0 [filamentLA] bed_temperature = 57 bridge_fan_speed = 100 cooling = 1 disable_fan_first_layers = 3 extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 60 filament_diameter = 1.75 first_layer_bed_temperature = 57 first_layer_temperature = 0 max_fan_speed = 100 min_fan_speed = 100 min_print_speed = 10 slowdown_below_layer_time = 20 temperature = 0 [presets] filament = PLA.ini filament_1 = PLA print = 0.5mm Nozzle.ini printer = Ormerod PLA 0.5mm Single Nozzle.ini [print:0.3mm Nozzle] avoid_crossing_perimeters = 0 bottom_solid_layers = 3 bridge_acceleration = 0 bridge_flow_ratio = 1 bridge_speed = 30 brim_width = 0 complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0.3 external_perimeter_speed = 30 external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0.3 fill_angle = 45 fill_density = 20% fill_pattern = rectilinear first_layer_acceleration = 0 first_layer_extrusion_width = 0.5 first_layer_height = 0.3 first_layer_speed = 50% gap_fill_speed = 20 gcode_comments = 0 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0.3 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 40 interface_shells = 0 layer_height = 0.2 min_skirt_length = 0 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0.3 perimeter_speed = 30 perimeters = 2 post_process = raft_layers = 0 resolution = 0 seam_position = aligned skirt_distance = 3 skirt_height = 1 skirts = 1 small_perimeter_speed = 30 solid_infill_below_area = 0 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0.3 solid_infill_speed = 30 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0.3 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = pillars support_material_spacing = 2.5 support_material_speed = 40 support_material_threshold = 0 thin_walls = 1 threads = 2 top_infill_extrusion_width = 0.3 top_solid_infill_speed = 30 top_solid_layers = 3 travel_speed = 150 xy_size_compensation = -0.05 [print:0.5mm Nozzle] avoid_crossing_perimeters = 0 bottom_solid_layers = 3 bridge_acceleration = 0 bridge_flow_ratio = 1 bridge_speed = 40 brim_width = 0 complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0.5 external_perimeter_speed = 30 external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0.5 fill_angle = 45 fill_density = 20% fill_pattern = rectilinear first_layer_acceleration = 0 first_layer_extrusion_width = 0.8 first_layer_height = 0.3 first_layer_speed = 50% gap_fill_speed = 20 gcode_comments = 0 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0.5 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 40 interface_shells = 0 layer_height = 0.3 min_skirt_length = 0 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0.5 perimeter_speed = 30 perimeters = 2 post_process = raft_layers = 0 resolution = 0 seam_position = aligned skirt_distance = 3 skirt_height = 1 skirts = 1 small_perimeter_speed = 30 solid_infill_below_area = 0 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0.5 solid_infill_speed = 30 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0.5 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = pillars support_material_spacing = 2.5 support_material_speed = 40 support_material_threshold = 0 thin_walls = 1 threads = 2 top_infill_extrusion_width = 0.5 top_solid_infill_speed = 30 top_solid_layers = 3 travel_speed = 150 xy_size_compensation = -0.05 [printer:Ormerod ABS 0.3mm Dual Nozzle] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures\nG10 P1 S-273 R-273 ; Set tool 0 operating and standby temperatures\nM140 S40 extruder_offset = 0x0,0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.3,0.3 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2,2 retract_layer_change = 1,1 retract_length = 3.5,3.5 retract_length_toolchange = 10,10 retract_lift = 0,0 retract_restart_extra = 0,0 retract_restart_extra_toolchange = 0,0 retract_speed = 40,40 start_gcode = G28 ; home all axes\nM83;\nG10 P0 S240 R210 ; Set tool 0 operating and standby temperatures\nG10 P1 S240 R210 ; Set tool 1 operating and standby temperatures toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0,0 z_offset = 0 [printer:Ormerod ABS 0.3mm Single Nozzle] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures\nM140 S40 extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.3 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 1 retract_length = 3.5 retract_length_toolchange = 10 retract_lift = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 start_gcode = G28 ; home all axes\nM83;\nG10 P0 S240 R210 ; Set tool 0 operating and standby temperatures\nT0\n toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 z_offset = 0 [printer:Ormerod ABS 0.5mm Dual Nozzle] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures\nG10 P1 S-273 R-273 ; Set tool 0 operating and standby temperatures\nM140 S40 extruder_offset = 0x0,0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.5,0.5 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2,2 retract_layer_change = 1,1 retract_length = 3.5,3.5 retract_length_toolchange = 10,10 retract_lift = 0,0 retract_restart_extra = 0,0 retract_restart_extra_toolchange = 0,0 retract_speed = 40,40 start_gcode = G28 ; home all axes\nM83;\nG10 P0 S240 R210 ; Set tool 0 operating and standby temperatures\nG10 P1 S240 R210 ; Set tool 1 operating and standby temperatures toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0,0 z_offset = 0 [printer:Ormerod ABS 0.5mm Single Nozzle] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures\nM140 S40 extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.5 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 1 retract_length = 3.5 retract_length_toolchange = 10 retract_lift = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 start_gcode = G28 ; home all axes\nM83;\nG10 P0 S240 R210 ; Set tool 0 operating and standby temperatures\nT0\n toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 z_offset = 0 [printer:Ormerod PLA 0.3mm Dual Nozzle] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures\nG10 P1 S-273 R-273 ; Set tool 0 operating and standby temperatures\nM140 S40 extruder_offset = 0x0,0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.3,0.3 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2,2 retract_layer_change = 1,1 retract_length = 3.5,3.5 retract_length_toolchange = 10,10 retract_lift = 0,0 retract_restart_extra = 0,0 retract_restart_extra_toolchange = 0,0 retract_speed = 40,40 start_gcode = G28 ; home all axes\nM83;\nG10 P0 S195 R160 ; Set tool 0 operating and standby temperatures\nG10 P1 S195 R160 ; Set tool 0 operating and standby temperatures toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0,0 z_offset = 0 [printer:Ormerod PLA 0.3mm Single Nozzle] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures\nM140 S40 extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.3 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 1 retract_length = 3.5 retract_length_toolchange = 10 retract_lift = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 start_gcode = G28 ; home all axes\nM83;\nG10 P0 S195 R160 ; Set tool 0 operating and standby temperatures\nT0\n toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 z_offset = 0 [printer:Ormerod PLA 0.5mm Dual Nozzle] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures\nG10 P1 S-273 R-273 ; Set tool 0 operating and standby temperatures\nM140 S40 extruder_offset = 0x0,0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.5,0.5 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2,2 retract_layer_change = 1,1 retract_length = 3.5,3.5 retract_length_toolchange = 10,10 retract_lift = 0,0 retract_restart_extra = 0,0 retract_restart_extra_toolchange = 0,0 retract_speed = 40,40 start_gcode = G28 ; home all axes\nM83;\nG10 P0 S195 R160 ; Set tool 0 operating and standby temperatures\nG10 P1 S195 R160 ; Set tool 0 operating and standby temperatures toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0,0 z_offset = 0 [printer:Ormerod PLA 0.5mm Single Nozzle] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures\nM140 S40 extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.5 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 1 retract_length = 3.5 retract_length_toolchange = 10 retract_lift = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 start_gcode = G28 ; home all axes\nM83;\nG10 P0 S195 R160 ; Set tool 0 operating and standby temperatures\nT0\n toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 z_offset = 0 [settings] autocenter = 1 mode = expert
Re: HELP -----> Need slic3r config - Start/End G-Code December 06, 2018 03:11PM |
