HELP -----> Need slic3r config - Start/End G-Code
Posted by ormerod2_user
September 16, 2018 02:16PM
Hi, I lost my slic3r config.
I can't seem to find one for the ormerod2 anywhere online. I'm hoping someone can help me out as I'm very rusty with my printer. I was able to import the config from an old gcode file in slic3r; but it didn't seem to preserve my start/end G-codes. I had it setup real nice before. It would home axis, heat the nozzle/bed, and go home after the part was finished and turn off the heaters. I need a good starting point as I forgot most everything I knew.
Any help would be greatly appreciated. Thank you.
Re: HELP -----> Need slic3r config - Start/End G-Code
September 18, 2018 12:11PM
Config can be found here
[github.com]
Name it config.ini and place in slic3r directory
The line with the smiley should read
PLA
# generated by Slic3r 1.2.6 on Tue May  5 11:18:25 2015
[filament:ABS]
bed_temperature = 100
bridge_fan_speed = 100
cooling = 1
disable_fan_first_layers = 3
extrusion_multiplier = 1
fan_always_on = 0
fan_below_layer_time = 20
filament_diameter = 1.75
first_layer_bed_temperature = 100
first_layer_temperature = 0
max_fan_speed = 100
min_fan_speed = 0
min_print_speed = 10
slowdown_below_layer_time = 20
temperature = 0
[filamenttongue sticking out smileyLA]
bed_temperature = 57
cooling = 1
fan_always_on = 1
fan_below_layer_time = 60
first_layer_bed_temperature = 57
max_fan_speed = 100
min_fan_speed = 100
temperature = 0
[presets]
filament = PLA.ini
filament_1 = PLA
print = 0.5mm Nozzle.ini
printer = Ormerod PLA 0.5mm Single Nozzle.ini
[print:0.3mm Nozzle]
avoid_crossing_perimeters = 0
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_flow_ratio = 1
bridge_speed = 30
brim_width = 0
complete_objects = 0
default_acceleration = 0
dont_support_bridges = 1
external_fill_pattern = rectilinear
external_perimeter_extrusion_width = 0.3
external_perimeter_speed = 30
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
fill_angle = 45
fill_density = 20%
first_layer_acceleration = 0
first_layer_extrusion_width = 0.5
first_layer_height = 0.3
first_layer_speed = 50%
gap_fill_speed = 20
gcode_comments = 0
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0.3
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 15%
infill_speed = 40
interface_shells = 0
layer_height = 0.2
min_skirt_length = 0
notes =
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeters = 2
post_process =
raft_layers = 0
resolution = 0
seam_position = aligned
skirt_distance = 3
skirt_height = 1
skirts = 1
small_perimeter_speed = 30
solid_infill_below_area = 0
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0.3
solid_infill_speed = 30
spiral_vase = 0
standby_temperature_delta = -5
support_material = 0
support_material_angle = 0
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0.3
support_material_interface_extruder = 1
support_material_interface_layers = 3
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = pillars
support_material_spacing = 2.5
support_material_speed = 40
support_material_threshold = 0
thin_walls = 1
threads = 2
top_infill_extrusion_width = 0.3
top_solid_infill_speed = 30
top_solid_layers = 3
travel_speed = 150
xy_size_compensation = -0.05
[print:0.5mm Nozzle]
bridge_speed = 40
brim_width = 0
external_perimeter_extrusion_width = 0.5
fill_angle = 45
fill_density = 20%
first_layer_extrusion_width = 0.8
gap_fill_speed = 20
gcode_comments = 0
infill_extruder = 1
infill_extrusion_width = 0.5
infill_first = 0
infill_speed = 40
layer_height = 0.3
notes =
ooze_prevention = 0
overhangs = 1
perimeters = 2
post_process =
raft_layers = 0
resolution = 0
skirt_distance = 3
skirt_height = 1
skirts = 1
solid_infill_extrusion_width = 0.5
spiral_vase = 0
support_material_extrusion_width = 0.5
thin_walls = 1
threads = 2
top_infill_extrusion_width = 0.5
travel_speed = 150
[printer:Ormerod ABS 0.3mm Dual Nozzle]
bed_shape = 0x0,200x0,200x200,0x200
before_layer_gcode =
end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273                       ; Set tool 0 operating and standby temperatures\nG10 P1 S-273 R-273               ; Set tool 0 operating and standby temperatures\nM140 S40
extruder_offset = 0x0,0x0
gcode_flavor = reprap
layer_gcode =
nozzle_diameter = 0.3,0.3
octoprint_apikey =
octoprint_host =
pressure_advance = 0
retract_before_travel = 2,2
retract_layer_change = 1,1
retract_length = 3.5,3.5
retract_length_toolchange = 10,10
retract_lift = 0,0
retract_restart_extra = 0,0
retract_restart_extra_toolchange = 0,0
retract_speed = 40,40
start_gcode = G28 ; home all axes\nM83;\nG10 P0 S240 R210                       ; Set tool 0 operating and standby temperatures\nG10 P1 S240 R210               ; Set tool 1 operating and standby temperatures
toolchange_gcode =
use_firmware_retraction = 0
use_relative_e_distances = 1
use_volumetric_e = 0
vibration_limit = 0
wipe = 0,0
z_offset = 0
[printer:Ormerod ABS 0.3mm Single Nozzle]
end_gcode = G1 X2 Y190 F9000\nG4 S0\nG10 P0 S-273 R-273                       ; Set tool 0 operating and standby temperatures\nM140 S40
layer_gcode =
octoprint_apikey =
octoprint_host =
retract_lift = 0
retract_speed = 40
start_gcode = G28 ; home all axes\nM83;\nG10 P0 S240 R210                       ; Set tool 0 operating and standby temperatures\nT0\n
toolchange_gcode =
vibration_limit = 0
wipe = 0
z_offset = 0
[printer:Ormerod ABS 0.5mm Dual Nozzle]
layer_gcode =
nozzle_diameter = 0.5,0.5
octoprint_apikey =
octoprint_host =
retract_lift = 0,0
toolchange_gcode =
vibration_limit = 0
wipe = 0,0
z_offset = 0
[printer:Ormerod ABS 0.5mm Single Nozzle]
layer_gcode =
octoprint_apikey =
octoprint_host =
retract_lift = 0
retract_speed = 40
toolchange_gcode =
vibration_limit = 0
wipe = 0
z_offset = 0
[printer:Ormerod PLA 0.3mm Dual Nozzle]
layer_gcode =
octoprint_apikey =
octoprint_host =
retract_lift = 0,0
start_gcode = G28 ; home all axes\nM83;\nG10 P0 S195 R160                       ; Set tool 0 operating and standby temperatures\nG10 P1 S195 R160               ; Set tool 0 operating and standby temperatures
toolchange_gcode =
vibration_limit = 0
wipe = 0,0
z_offset = 0
[printer:Ormerod PLA 0.3mm Single Nozzle]
layer_gcode =
octoprint_apikey =
octoprint_host =
retract_lift = 0
retract_speed = 40
start_gcode = G28 ; home all axes\nM83;\nG10 P0 S195 R160                       ; Set tool 0 operating and standby temperatures\nT0\n
toolchange_gcode =
vibration_limit = 0
wipe = 0
z_offset = 0
[printer:Ormerod PLA 0.5mm Dual Nozzle]
layer_gcode =
octoprint_apikey =
octoprint_host =
retract_lift = 0,0
toolchange_gcode =
vibration_limit = 0
wipe = 0,0
z_offset = 0
[printer:Ormerod PLA 0.5mm Single Nozzle]
layer_gcode =
octoprint_apikey =
octoprint_host =
retract_lift = 0
retract_speed = 40
toolchange_gcode =
vibration_limit = 0
wipe = 0
z_offset = 0
[settings]
autocenter = 1
mode = expert
December 06, 2018 03:11PM
Ok Guys there is a BIG problem here.
I have saved both the .ini from GET Hub as well as the .ini code that you shared here.
Also with both of them, if you go to FILAMENT then it states DIAMETER 3mm eye popping smiley
What else might be wrong in this file?
Edited 2 time(s). Last edit at 12/06/2018 04:17PM by Karoo Klong.
