Show us your settings!
Posted by WesBrooks
November 12, 2018 06:24PM
Hi all,
I'm interested in comparing settings. I've been having a right fight with the benchy and specifically the bow and rear corners. All tend to curl up. I had thought this was purely a cooling issue but when I tried faster processing settings the curl became much worse. So here are my critical config settings and the Slic3r settings:
M92 X87.489 Y87.489 Z400 E425.2 ; Set steps per mm
M566 X900 Y900 Z12 E800 ; Set maximum instantaneous speed changes (mm/min)
M203 X12000 Y12000 Z1200 E8000 ; Set maximum speeds (mm/min)
M201 X3000 Y3000 Z250 E500 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
Print Settings - Advanced
Default Extrusion width 0.55mm
First Layer: 265%
Perimeter: 0.50
(external) 0.50
Infill 0.575
(Solid) 0.53
(top solid) 0.53
Infill / perimiters overlap 75%
Bridge Flow ratio 1.05 (think I need to increase)
Print Settings - Speed
Perimieters 40
(small) 25
(external) 50%
Infill 55
(solid) 45
(top solid) 45
(gaps) 20
Bridges 25
Support Material 40
Nozzle Diameter = 0.5mm
These have given a PLA benchy with a slightly shiny finish. My next trial will be dropping to 0.15mm but increasing the speed. My thought here is that the smaller incremental addition of polymer may cool better than a big chunk.
Re: Show us your settings!
November 12, 2018 06:29PM
Layer thickness: 0.20mm
Print temps: 195/190
Bed temp: 60/60
November 13, 2018 05:11AM
M92 X87.489 Y87.489 Z4000 E420:420                 ; Set steps per mm
M201 X500 Y500 Z250 E500:500            ; Accelerations (mm/s^2)
M203 X15000 Y15000 Z100 E3600       ; Maximum speeds (mm/min)
M566 X900 Y900 Z12 E120:120              ; Set maximum instantaneous speed changes (mm/min)
M906 X1000 Y1200 Z1000 E1200:1200 I30              ; Set motor currents (mA) and motor idle factor in per cent
M84 S30
# generated by Slic3r Prusa Edition 1.41.1+win64 on 2018-11-12 at 23:49:56
[print:Ormerod 2 (0.3mm) v1.1]
avoid_crossing_perimeters = 0
bottom_solid_layers = 5
bridge_acceleration = 0
bridge_angle = 0
bridge_flow_ratio = 1
bridge_speed = 40
brim_width = 0
clip_multipart_objects = 0
compatible_printers =
compatible_printers_condition =
complete_objects = 0
default_acceleration = 0
dont_support_bridges = 1
elefant_foot_compensation = 0
ensure_vertical_shell_thickness = 0
external_fill_pattern = rectilinear
external_perimeter_extrusion_width = 0.5
external_perimeter_speed = 45
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
fill_angle = 45
fill_density = 20%
fill_pattern = grid
first_layer_acceleration = 0
first_layer_extrusion_width = 0.8
first_layer_height = 0.3
first_layer_speed = 50%
gap_fill_speed = 10
gcode_comments = 1
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0.5
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 25%
infill_speed = 45
inherits =
interface_shells = 0
layer_height = 0.3
max_print_speed = 80
max_volumetric_extrusion_rate_slope_negative = 0
max_volumetric_extrusion_rate_slope_positive = 0
max_volumetric_speed = 0
min_skirt_length = 0
notes =
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeters = 3
post_process =
print_settings_id =
raft_layers = 0
resolution = 0
seam_position = aligned
single_extruder_multi_material_priming = 1
skirt_distance = 2
skirt_height = 1
skirts = 1
small_perimeter_speed = 32
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0.5
solid_infill_speed = 40
spiral_vase = 0
standby_temperature_delta = -5
support_material = 1
support_material_angle = 0
support_material_auto = 1
support_material_buildplate_only = 1
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_contact_loops = 0
support_material_interface_extruder = 1
support_material_interface_layers = 3
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 40
support_material_synchronize_layers = 0
support_material_threshold = 0
support_material_with_sheath = 1
support_material_xy_spacing = 50%
thin_walls = 1
threads = 4
top_infill_extrusion_width = 0.5
top_solid_infill_speed = 40
top_solid_layers = 5
travel_speed = 130
wipe_tower = 0
wipe_tower_bridging = 10
wipe_tower_rotation_angle = 0
wipe_tower_width = 60
wipe_tower_x = 180
wipe_tower_y = 140
xy_size_compensation = 0
[filament:Ormerod 2 PLA 35% fan]
bed_temperature = 40
bridge_fan_speed = 35
cooling = 1
disable_fan_first_layers = 3
end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n"
extrusion_multiplier = 1
fan_always_on = 1
fan_below_layer_time = 100
filament_colour = #FF0000
filament_cooling_final_speed = 3.4
filament_cooling_initial_speed = 2.2
filament_cooling_moves = 4
filament_cost = 25.4
filament_density = 1.24
filament_diameter = 1.75
filament_load_time = 0
filament_loading_speed = 28
filament_loading_speed_start = 3
filament_max_volumetric_speed = 0
filament_minimal_purge_on_wipe_tower = 15
filament_notes = ""
filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
filament_settings_id = ""
filament_soluble = 0
filament_toolchange_delay = 0
filament_type = PLA
filament_unload_time = 0
filament_unloading_speed = 90
filament_unloading_speed_start = 100
first_layer_bed_temperature = 50
first_layer_temperature = 210
inherits =
max_fan_speed = 35
min_fan_speed = 3
min_print_speed = 10
slowdown_below_layer_time = 20
start_filament_gcode = "; Filament gcode\n"
temperature = 210
[filament:Ormerod 2 PLA V1.1]
cooling = 1
fan_always_on = 1
filament_notes = ""
filament_type = PLA
inherits =
max_fan_speed = 20
min_fan_speed = 3
temperature = 210
[printer:Ormerod 2 v1.2]
bed_shape = 0x0,200x0,200x200,0x200
before_layer_gcode =
between_objects_gcode =
cooling_tube_length = 5
cooling_tube_retraction = 91.5
default_filament_profile = ""
default_print_profile =
deretract_speed = 0,0
end_gcode = G10 P0 R0 S0        ; Set tool 0 operating and standby temperatures\nG10 P1 R0 S0        ; Set tool 1 operating and standby temperatures\nG28 X0  ; home X axis\nM84     ; disable motors\nM140  S0 ;\nM140  S-273\n\n
extra_loading_move = -2
extruder_colour = #0000FF;#FF0000
extruder_offset = 0x0,0x0
gcode_flavor = marlin
host_type = duet
inherits =
layer_gcode =
machine_max_acceleration_e = 500,250
machine_max_acceleration_extruding = 500,250
machine_max_acceleration_retracting = 500,250
machine_max_acceleration_x = 500,250
machine_max_acceleration_y = 500,250
machine_max_acceleration_z = 250,250
machine_max_feedrate_e = 1200,600
machine_max_feedrate_x = 6000,3000
machine_max_feedrate_y = 6000,3000
machine_max_feedrate_z = 180,90
machine_max_jerk_e = 120,60
machine_max_jerk_x = 900,450
machine_max_jerk_y = 900,450
machine_max_jerk_z = 12,6
machine_min_extruding_rate = 0,0
machine_min_travel_rate = 0,0
max_layer_height = 0.4,0.4
max_print_height = 170
min_layer_height = 0.07,0.07
nozzle_diameter = 0.5,0.5
parking_pos_retraction = 92
print_host = 192.168.0.26
printer_model =
printer_notes =
printer_settings_id =
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_before_travel = 2,2
retract_before_wipe = 0%,0%
retract_layer_change = 1,1
retract_length = 2,2
retract_length_toolchange = 10,10
retract_lift = 0,0
retract_lift_above = 0,0
retract_lift_below = 0,0
retract_restart_extra = 0,0
retract_restart_extra_toolchange = 0,0
retract_speed = 40,40
serial_port =
serial_speed = 250000
silent_mode = 1
single_extruder_multi_material = 0
start_gcode = M201 X500 Y500 Z250 E500:500            ; Accelerations (mm/s^2)\nM203 X15000 Y15000 Z100 E3600       ; Maximum speeds (mm/min)\nM566 X900 Y900 Z12 E120:120              ; Set maximum instantaneous speed changes (mm/min)\n\nG28 ; home all axes\nG1 Z1 F5000 ; lift nozzle
toolchange_gcode =
use_firmware_retraction = 0
use_relative_e_distances = 1
use_volumetric_e = 0
variable_layer_height = 1
wipe = 0,0
z_offset = 0
Your settings are fairly similar to mine.
Do you have a layer cooling fan, that is the biggest improvement for curling after the first few layers.
For the first few layers, an enclosure & a decent build surface like PEI, PrintBite+ or LokBuild.
November 13, 2018 05:16AM
Yeah, got the stock part cooling fan mounted on the hotend but think the fan is naff. Just looking to mount a radial blower.
November 14, 2018 09:36AM
Benchies succesful at 0.2 and 0.3mm followed by a Hellboy head! Happy as. I'll update this with tje settings I used when I get a chance. Potential for speeding up the 0.2mm builds but 0.3 where at the point where I get extruder drive issues on a calibration extrusion into free space, so not pushing any further with speeds on that!
50mm radial fan mounted on the same bracket as the stock fan (holes drilled out to suit M3 bolts in situe) made all the difference.
November 14, 2018 12:40PM
Here,s my slic3r advanced.
Ormerod 113
open | download - Slic3r.jpg (108.1 KB)
