The Alumarod needs manual mesh bed leveling November 14, 2018 11:00AM |
Re: The Alumarod needs manual mesh bed leveling November 14, 2018 11:16AM |
Re: The Alumarod needs manual mesh bed leveling November 14, 2018 12:29PM |
Re: The Alumarod needs manual mesh bed leveling November 14, 2018 02:05PM |
Re: The Alumarod needs manual mesh bed leveling November 14, 2018 05:42PM |
Re: The Alumarod needs manual mesh bed leveling November 15, 2018 04:37AM |
Re: The Alumarod needs manual mesh bed leveling November 15, 2018 06:02AM |
Re: The Alumarod needs manual mesh bed leveling November 15, 2018 09:10AM |
Re: The Alumarod needs manual mesh bed leveling November 15, 2018 05:42PM |
Re: The Alumarod needs manual mesh bed leveling November 16, 2018 04:21AM |
Re: The Alumarod needs manual mesh bed leveling November 16, 2018 05:15AM |
Re: The Alumarod needs manual mesh bed leveling November 16, 2018 06:23AM |
Re: The Alumarod needs manual mesh bed leveling November 16, 2018 06:36AM |
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool on Fri Nov 16 2018 11:24:50 GMT+0000 (Greenwich Mean Time) M561 ; clear any bed transform ; Probe the bed at 4 points G30 P0 X25 Y25 H0 Z-99999 G30 P1 X25 Y175 H0 Z-99999 G30 P2 X175 Y175 H0 Z-99999 G30 P3 X175 Y25 H0 Z-99999 S
G31 P500 X30 Y0 Z0.8
M558 P1 X1 Y0 Z1 H5 F120 T6000(but I can't check this as I'm at work at the moment and I have an Ormerod 2 anyway so may be different)
Re: The Alumarod needs manual mesh bed leveling November 16, 2018 06:53AM |
Re: The Alumarod needs manual mesh bed leveling November 16, 2018 07:00AM |
Re: The Alumarod needs manual mesh bed leveling November 16, 2018 11:05AM |
Re: The Alumarod needs manual mesh bed leveling November 17, 2018 05:47AM |
cheeseandham
Karoo,
Zip up your whole sys directory and attach it here, I'll be happy to take a look this weekend at some point.
(you should be able to do it from the web interface, just select all the files and right click , save as zip)
Re: The Alumarod needs manual mesh bed leveling November 20, 2018 01:47PM |
; Configuration file for Duet 0.6 (firmware version 1.17 to 1.19) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Tue Nov 20 2018 18:26:14 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M550 PMichiel Ormerod 1 ; Set machine name M552 P192.168.1.240 ; IP address M553 P255.255.255.0 ; Netmask M554 P192.168.1.1 ; Gateway M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M92 X87.489 Y87.489 Z4000 E420 ; Set steps per mm M566 X1800 Y1800 Z30 E20 ; Set maximum instantaneous speed changes (mm/min) M203 X15000 Y15000 Z250 E3600 ; Set maximum speeds (mm/min) M201 X500 Y500 Z20 E250 ; Set accelerations (mm/s^2) M906 X1000 Y1200 Z800 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X210 Y205 Z185 S0 ; Set axis maxima ; Endstops M574 X0 Z0 S0 ; Set active low endstops M574 Y2 S1 ; Set active high endstops ; Z-Probe M558 P1 X1 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the dive height + speeds G31 P500 X0 Y0 Z0.2 ; Set Z probe trigger value, offset and trigger height M556 S0 X0 Y0 Z0 ; Set orthogonal axis compensation parameters M557 X15:215 Y15:195 S20 ; Define mesh grid ; Heaters M305 P0 T10000 B3988 C0 R1000 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 C0 R1000 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R-273 S-273 ; Set initial tool 0 active and standby temperatures to 0C ; Custom settings are not configured
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 12:38PM |
I understand and appreciate your time and effort to try and help me very much.Quote
cheeseandham
I've had a look, please remember I'm not an expert, just an enthusiastic amateur!
That is correct, I have an Ormerod 1, of the origional RS branded modelsQuote
cheeseandham
I've not seen you specify exactly which Ormerod, I get the impression that you are using an Ormerod 1, and my information is based on this assumption.
Yes the config.g was one that I started editing and has the Home Z sorted outQuote
cheeseandham
There are 3 config.g files here, so I'm just going on the main config.g
No you may have misread that, G31 has a P value of 365 at 0.05mm (I am assuming the 0.2 should be in mm right?)Quote
cheeseandham
i) I note your G31 has a P value of 365 and 0.2 - this IMHO is a biggie. The sensors I am familiar with require a P value of 500 or 600 and typically are not sensitive at lower values.
Yes that was the main problem I did not have a bed.g and did not know how to get hold of one.Quote
cheeseandham
ii) you have no bed.g for G32. While this is deprecated, before mesh leveling I feel you need to get (i) sorted, and G32 working (as it is simpler IMO)
Thank you for this, I tried using the RepRap configurator but got stuck at some of the requeted information. I did not know how and where to find all that information.Quote
cheeseandham
using your values in your config.g and putting it through the Reprap configurator, you get a much nicer config.g with which to work with (and bed.g , homeall.g etc)
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 01:06PM |
Karoo Klong
Karoo Klong
I copied the sys folder over to an sd card and inserted it into my printer. I tried connecting via Duet Web Controld and get the following Ajax Communication Error;
An AJAX error has been reported, so the current session has been terminated.
Please check if your printer is still on and try to connect again.
Error reason: SyntaxError: Unexpected token a in JSON at position 65
Any Idea what this might mean?
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 02:42PM |
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 03:45PM |
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 04:09PM |
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 04:11PM |
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 04:13PM |
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 06:48PM |
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 07:03PM |
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 07:07PM |
Re: The Alumarod needs manual mesh bed leveling November 21, 2018 07:37PM |
Re: The Alumarod needs manual mesh bed leveling November 22, 2018 01:57AM |
