(Guide) Swapping from bed.g to 4 point mesh with repeat probes. November 23, 2018 03:23AM |
M561 ; clear any bed transform ; Probe the bed at 4 points G30 P0 X65 Y5 H0 Z-99999 G30 P1 X65 Y195 H0 Z-99999 G30 P2 X228 Y195 H0 Z-99999 G30 P3 X228 Y5 H0 Z-99999 S
M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds G31 P608 X0 Y0 Z2.35 ; Set Z probe trigger value, offset and trigger height
M558 P1 H5 F120 T6000 A5 S0.03 ; Set Z probe type to unmodulated (P1). Dive height (H5). Speeds ; (Probe - F120, travel - T6000). Probe each point 5 times (A5) maximum ; in order to reach 0.03mm tolerance (S0.03). M557 X65:228 Y5:195 S163:190 ; Define mesh grid (X[min x]:[max x] Y[min-y]:[max-y] ; S[x spacing of mesh grid]:[y spacing of mesh grid])
Re: (Guide) Swapping from bed.g to 4 point mesh with repeat probes. November 23, 2018 05:07AM |
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 23 2018 10:04:45 GMT+0000 (Greenwich Mean Time) M561 ; clear any bed transform G28 ; home all axes G29 ; probe the bed and enable compensation
Re: (Guide) Swapping from bed.g to 4 point mesh with repeat probes. November 23, 2018 07:01AM |
Re: (Guide) Swapping from bed.g to 4 point mesh with repeat probes. November 23, 2018 07:05AM |
Re: (Guide) Swapping from bed.g to 4 point mesh with repeat probes. November 23, 2018 10:59AM |
