Banding on walls? January 21, 2019 04:28AM |
Re: Banding on walls? January 22, 2019 08:03AM |
Re: Banding on walls? January 22, 2019 08:05AM |
Re: Banding on walls? January 22, 2019 05:09PM |
Re: Banding on walls? January 24, 2019 07:00AM |
Re: Banding on walls? January 24, 2019 07:05AM |
Re: Banding on walls? January 24, 2019 07:54AM |
cheeseandham
* Check the temp. isn't changing while printing.
Re: Banding on walls? January 24, 2019 08:03AM |
Re: Banding on walls? January 25, 2019 05:42AM |
veryevil
Interesting, not thought of that. Mine is an omerod 2 so using cheap Chinese supply not ATX supply.
If you have the time and opportunity, I'd be tempted to go back to stock configuration first, as there should be no ringing with the threaded rod - see if it has any effect and then retry your trapezoidal rod.Quote
veryevil
I do have a trapezoidal rod for my z axis and I did completely rework my z axis to be behind the linear rod. I thought keeping the rod and screw in line would help with bed level and squareness but I think it's made the end of my X axis prone to vibrations.
Currently printing a whole new z axis set up bringing it back at 90° in line with the z axis extrusion as originally.
