Duet - Ethernet dead? August 19, 2019 06:05PM |
Re: Duet - Ethernet dead? August 20, 2019 06:37PM |
Re: Duet - Ethernet dead? August 21, 2019 04:24PM |
dc42
It sounds to me that the PHY chip is probably blown or has a bad solder joint under it. That's the small square one not far from the Ethernet socket.
BTW the Duet Maestro make a good replacement for the Duet 0.6 in an Ormerod, although if it is an Ormerod 1 then you will need new bed cables.
Re: Duet - Ethernet dead? August 22, 2019 03:02AM |
