Ormerod fell down, need acrylic parts
Posted by Sardi
February 12, 2020 11:02AM
The topic says it all.. The fillament roll was tangled, pulled the ormerod down from the table about 80cm high.
Both acrylic parts of the Y axis (one near the motor bracket and other the idler bracket) are smashed into pieces and cant be glued any more.
Any stl anywhere for them? I cant seem to find them.
And if not, any suggestions on what I should do? I am in the middle of an order and need a solution asap.
Re: Ormerod fell down, need acrylic parts
February 12, 2020 04:37PM
Have you tried [github.com] ?
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
February 14, 2020 10:22AM
Managed to stick all broken parts together with aluminum tape, holds strong enough for me to print spare parts.
I found a folder on my pc with a lot of dxf files of ormerod parts, so Im printing from it.
February 21, 2020 10:42AM
If you're stuck for parts any need something laser cut or printed, then we can quote for that.
Sally
RepRap Ltd
March 07, 2020 05:43AM
I have a spare set of acrylic parts for original Ormerod if you still need some?
RS Ormerod #472
