Hi everybody!
My problem is a bit weird and I've done all I could think of to "fix" it.
I'm running repetier both on the printer and the PC. Everything works and the printer is usable (quite good actually). I just now noticed this issue since it's the first time I wanted to print something above 80mm in height.
There is no error message.
It tells me it is going up to the set max height and it starts to turn the motors only when coming under the 80mm value.
I have checked everything everywhere! My only last option is to install a z-max endstop.
Does anybody here have any suggestions? I have room to take the axis up to 150mm! So, naturally, I am upset to not be able to use half the height.
Edited 1 time(s). Last edit at 05/26/2014 09:35AM by adibadro.
