Modified Configuration.h file for easy use and reading January 27, 2015 03:08PM |
Re: Modified Configuration.h file for easy use and reading January 28, 2015 04:08AM |
Re: Modified Configuration.h file for easy use and reading January 28, 2015 07:07AM |
Re: Modified Configuration.h file for easy use and reading January 28, 2015 01:35PM |
// HOT END THERMISTOR PID TUNING: // Define PID temperatures. // Set the maximum current. // Limit the current to the hot end nozzle while PID is active. // If the difference between target temperature and the actual temperature > PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max. // Set the limit for the integral term. // Set the smoothing factor within the PID. // Set the ampling period of the temperature routine. // Set the default PID temperature settings for an Ultimaker type hot end. Change using results from M503 after cooldown. // Set the default PID temperature settings for an Ultimaker type hot end. Change using results from M503 after cooldown. // Set the default PID temperature settings for an Ultimaker type hot end. Change using results from M503 after cooldown. #define PIDTEMP #define BANG_MAX 255 #define PID_MAX 255 #define PID_FUNCTIONAL_RANGE 10 #define PID_INTEGRAL_DRIVE_MAX 255 #define K1 0.95 #define PID_dT ((OVERSAMPLENR * 8.0)/(F_CPU / 64.0 / 256.0)) // If you have run the PID Autotune (M303), these are the values you want to change. #define DEFAULT_Kp 22.2 #define DEFAULT_Ki 1.08 #define DEFAULT_Kd 114
Re: Modified Configuration.h file for easy use and reading January 30, 2015 08:00PM |
Re: Modified Configuration.h file for easy use and reading February 18, 2015 10:23PM |
Re: Modified Configuration.h file for easy use and reading February 18, 2015 10:43PM |
Re: Modified Configuration.h file for easy use and reading February 26, 2015 11:08AM |
Re: Modified Configuration.h file for easy use and reading February 26, 2015 01:39PM |
Re: Modified Configuration.h file for easy use and reading February 26, 2015 06:32PM |
