Z Offset Pronterface & Cura March 23, 2015 02:48PM |
Re: Z Offset Pronterface & Cura March 23, 2015 03:09PM |
Re: Z Offset Pronterface & Cura March 23, 2015 04:17PM |
djinn5150
Well your close,
First lets get this out of the way...pick either the m555 or the z-offset in the host software...not both. I always just use the m555 and thats it.
My method to set Probe height is as follows
Run G28 X0 Y0
Then I G1 X100 Y100 (Replace the xy cooridinates for your bed center)
G30 ( this will probe the bed 1 time)
after the bed is probed I start lowering the axis by either 1mm or .1 mm depending on how close your probe is until it just grabs a peice of A4.
then its M555 z(whatever your move down distance was)
M500
That is my starting point then I will adjust by .05 until I get a first layer I am happy with.
If your not dead set on pronterface you might check out the newer version of Repetier host, it has cura slicing built in. I havent used pronterface in a long time so I cant really compare.
PS the M555 will expect a positve numbe in entry, it will move down that far after the probe, negative will raise it.
Re: Z Offset Pronterface & Cura March 23, 2015 04:34PM |
Re: Z Offset Pronterface & Cura March 23, 2015 04:40PM |
Re: Z Offset Pronterface & Cura March 23, 2015 05:15PM |
djinn5150
m114 will pump out the distance its traveled since the printer was initialized.
Re: Z Offset Pronterface & Cura March 23, 2015 05:28PM |
Re: Z Offset Pronterface & Cura March 23, 2015 05:40PM |
Re: Z Offset Pronterface & Cura March 23, 2015 09:51PM |
