HI all.
A friend of mine built a smartcore exactly like mine.
The only difference is the sensor: mine is a 4mm sensor his is a 8mm sensor.
I'm using the firmware from smartfriendz github repo, latest version for mk8.
I've try to do the same step i do to setup the autolevel:
- g28 to zero axis
- some G0 Z-0.1 -> -1.2 to put the noozle at a paper sheet distance
- put the value (-1.2) to marlin soft
- compile & flash
- try print.
This time the nozzle stay really high from glass: look like the "# define Z_PROBE_OFFSET_FROM_EXTRUDER -1.2" dosn't work at all.
Any suggestion to make it working like mine ? I'm missing something ?
Thanks.
