Heatbed Problem June 24, 2016 09:16AM |
Re: Heatbed Problem June 24, 2016 09:30AM |
Re: Heatbed Problem June 24, 2016 09:51AM |
#define TEMP_SENSOR_BED 11 <<< set this value to match your thermistor using a value from the table at the start of "Thermal Settings" section . . #define BED_MINTEMP 5 . . #define BED_MAXTEMP 150 . . #define PIDTEMPBED #define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current #ifdef PIDTEMPBED #define DEFAULT_bedKp 266.49 << replace this value with the value returned by M303 #define DEFAULT_bedKi 49.29 << replace with M303 value #define DEFAULT_bedKd 360.23 << replace with M303 value // FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degrees C for 8 cycles. #endif // PIDTEMPBED PID autotune
Re: Heatbed Problem June 24, 2016 10:20AM |
Connecting Power Connect your 12V power supply to the RAMPS shield. Reversing +/- or otherwise incorrectly connecting power can destroy your electronics and cause fire hazard. The bottom pair of connectors marked 5A power the stepper drivers and Extruder heater/fan (D9, D10). The source should be rated a minimum of 5A. The pair of connectors above marked 11A power a Heated Bed, or other output (D8). The source should be rated a minimum 11A (if both power rails are connected to the same supply it should have a minimum rating of 16A).
Re: Heatbed Problem June 24, 2016 10:51AM |
Re: Heatbed Problem June 24, 2016 11:31AM |
Re: Heatbed Problem June 24, 2016 11:43AM |
Re: Heatbed Problem June 25, 2016 06:27AM |
Re: Heatbed Problem June 27, 2016 07:19AM |
