Acceleration and Jerk July 05, 2016 05:13PM |
//// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {70*60, 70*60, 10*60, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,80,140} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 70, 50} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {6000,6000,2000,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 10.0 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Acceleration and Jerk July 05, 2016 07:31PM |
#define HOMING_FEEDRATE {70*60, 70*60, 15*50, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,200,1450} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 100, 45} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {3000,3000,500,250} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 1000 // X, Y, Z and E acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 50 // E acceleration in mm/s^2 for retracts #define DEFAULT_TRAVEL_ACCELERATION 1500 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 16.0 // (mm/sec) #define DEFAULT_ZJERK 1 // (mm/sec) #define DEFAULT_EJERK 0.1 // (mm/sec)
