SmartRap 3D printer January 26, 2014 11:42PM |
Re: SmartRap 3D printer January 27, 2014 12:37AM |
Re: SmartRap 3D printer January 28, 2014 07:03PM |
Re: SmartRap 3D printer January 29, 2014 10:12AM |
Re: SmartRap 3D printer January 31, 2014 04:05AM |
Re: SmartRap 3D printer February 03, 2014 05:33AM |
Re: SmartRap 3D printer February 14, 2014 06:26PM |
Re: SmartRap 3D printer February 14, 2014 07:10PM |
Re: SmartRap 3D printer February 16, 2014 04:36PM |
Re: SmartRap 3D printer February 17, 2014 10:46AM |
Re: SmartRap 3D printer March 07, 2014 06:44PM |
Re: SmartRap 3D printer March 08, 2014 12:00PM |
Re: SmartRap 3D printer March 08, 2014 12:32PM |
ldanut
This is my first post into reprap comunity. First of all I want to say hi to everybody for this fantastic work that have been done in this 3d printer comunity. I'm on my way building a reprap printer and already printed all the plastics and sourced almost all the parts. Can someone tell me what is the exact type of servo motor? I already purchased two variants from ebay and both are too big to fit into huxley end x part. I have this 9G SG90 type but I need a smaller one and I can't find it.
Thanks
Re: SmartRap 3D printer March 17, 2014 04:11AM |
Re: SmartRap 3D printer March 17, 2014 01:17PM |
Admin Registered: 16 years ago Posts: 1,470 |
I haven't built a SmartRap, but the electronics are going to be setup the same as any other printer. The two wires can be hooked up in a couple ways (NC = normally connected, C = common, NO = normally open, S = signal, GND = ground). NC and C to S and GND, or NO and C to S and GND. Which endstop wire goes to which RAMPS pin does not matter, i.e. NC to S and C to GND is equivalent to NC to GND and C to S. Whether you use NC or NO is personal preference. I recommend using NC if you only have endstops enabled for homing. This way, if a switch wire breaks or comes undone the printer won't crash an axis when homing, and it will be obvious that homing failed because the axis won't move to the home position.Quote
crd281
my conecern today is wiring my endstops. I've seen people talk about only using 2 wires from the endstops to the ramps but I have yet to see how they connect. (i.e. NC to which pin) I have tried searching the forums and get conflicting information about marlin. How has everyone been wiring these to your smartraps?
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: SmartRap 3D printer March 18, 2014 10:30PM |
Re: SmartRap 3D printer March 31, 2014 11:08PM |
