Verteez Smartrap build April 19, 2014 08:56AM |
Printing with Repetier Host, Cura, or from SD card works well.
Re: Verteez Smartrap build April 19, 2014 09:59AM |
G21 ; metric is good! G90 ; absolute positioning T0 ; select new extruder G28 ; go home G29 ; auto bed level G92 E0 ; set extruder home M104 S195.0 ; set temperature to 195.0 G1 X20 Y20 F500 ; move away from 0.0, to use the same reset for each layer
Re: Verteez Smartrap build April 19, 2014 12:57PM |
Re: Verteez Smartrap build April 19, 2014 03:37PM |
Re: Verteez Smartrap build April 20, 2014 04:07PM |
Re: Verteez Smartrap build April 20, 2014 04:11PM |
Re: Verteez Smartrap build April 20, 2014 05:21PM |
Re: Verteez Smartrap build April 20, 2014 06:00PM |
thx to all. |
Re: Verteez Smartrap build April 20, 2014 07:10PM |
verteez
Mark, I have made the microsteps today, but I have problem with them.
My motors are 48mm, so I have picked them in Marlin. After doing the math, like you said:
I'm having a 5 mm shaft and 0.30mm string, and 200 steps per revolution. If I not mistaken the result is 192,19 for me, but here's where the problem starts.
In the marlin, after changing the motor to 48mm, the control-motion shows the steps like they were with the 40mm motors, even after setting up the 40mm motor setting the same like for 48mm. Still after checking in the control-motion, nothing change. I still get the 99,00 value for the X and Y, 4000 for Z and 80 for extruder.
// default settings - smartrap: uses define on top for diferent motors config
#ifdef motors09
#define DEFAULT_AXIS_STEPS_PER_UNIT {394,394,7400,170} // smartrap : version 0.9 deg. 1/16 {382,382,7400,170}
#endif
#ifdef motors1848
#define DEFAULT_AXIS_STEPS_PER_UNIT {194,194,4000,85} // smartrap : version 1.8degv{194,194,4000,85}
#endif
#ifdef motors1840
#define DEFAULT_AXIS_STEPS_PER_UNIT {99,99,4000,80} // smartrap : version 1.8degv{194,194,4000,85} robotdigg.shaft adaptor,fishline big
#endif
Anny idea?
Re: Verteez Smartrap build April 21, 2014 04:49AM |
Re: Verteez Smartrap build April 21, 2014 04:56AM |
Re: Verteez Smartrap build April 21, 2014 07:00AM |
Re: Verteez Smartrap build April 22, 2014 06:16AM |
Re: Verteez Smartrap build April 22, 2014 06:17AM |
Re: Verteez Smartrap build April 22, 2014 10:31AM |
) I had already bought the parts for the GT2 conversion at the time though.|
Re: Verteez Smartrap build April 22, 2014 01:19PM |
Re: Verteez Smartrap build April 22, 2014 04:34PM |
Re: Verteez Smartrap build April 22, 2014 04:36PM |
Re: Verteez Smartrap build April 22, 2014 04:55PM |
Re: Verteez Smartrap build April 22, 2014 06:20PM |
The rest is PLA, expect the black piece which is ninjaflex, added as a gift from the shop-nice guys
Re: Verteez Smartrap build April 23, 2014 03:01AM |
Re: Verteez Smartrap build April 23, 2014 09:30AM |
Re: Verteez Smartrap build April 23, 2014 10:06AM |
Re: Verteez Smartrap build April 23, 2014 11:27AM |
I need to replace the coupler anyway as we need space there with new 40mm motors and shorter shaft. |
Re: Verteez Smartrap build April 23, 2014 08:35PM |
Re: Verteez Smartrap build April 24, 2014 03:35AM |
I have a terrible feeling inside that I did not buy my printer from Serge like others. I really wanted to help his project, but the euro is for me more than five times more expensive than my national currency ; _ ; mayby oter time will try to.
Re: Verteez Smartrap build April 24, 2014 03:48AM |
It's good idea. Really simple and took less place thank the z coupler
Re: Verteez Smartrap build April 24, 2014 07:53AM |
Re: Verteez Smartrap build April 24, 2014 02:34PM |
Re: Verteez Smartrap build April 24, 2014 03:46PM |
