Re: Verteez Smartrap build May 04, 2014 09:49AM |
Re: Verteez Smartrap build May 05, 2014 01:12PM |
Re: Verteez Smartrap build May 05, 2014 02:57PM |
Re: Verteez Smartrap build May 05, 2014 06:41PM |
Re: Verteez Smartrap build May 06, 2014 03:09PM |
I have just finished assembling and started the first print with it.
I still got the problem with extruder, will try to callibrate again. I have also noticed that my print was tilted in X axis, so I have stopped it(also of "airprinting"). Should I recallibrate the microstepping, or the stepper driver?
Re: Verteez Smartrap build May 06, 2014 04:29PM |
Re: Verteez Smartrap build May 06, 2014 05:56PM |
Re: Verteez Smartrap build May 08, 2014 12:00PM |
Re: Verteez Smartrap build May 08, 2014 05:25PM |
Re: Verteez Smartrap build May 08, 2014 06:06PM |
I got the same like you, the more I try to fix it, the more it's messed up..|
Re: Verteez Smartrap build May 08, 2014 07:20PM |
Re: Verteez Smartrap build May 08, 2014 07:56PM |
Re: Verteez Smartrap build May 08, 2014 08:02PM |
Re: Verteez Smartrap build May 08, 2014 09:01PM |
Re: Verteez Smartrap build May 09, 2014 02:32PM |
And no, the printed layers are not cooling to slow, I would say that they are fine. My problem is the filament comming out of the nozzle on itself, It's doing the biggest mess, and also ruin the first layers. I don't know how to stop it, I have checked the oozebane in slicer setting.
Mostly thanks to You, and lot of people from this forum. Im sad that I can't use cad, or similar things, so I'm not too big help to project
Re: Verteez Smartrap build May 09, 2014 03:40PM |
Re: Verteez Smartrap build May 09, 2014 03:53PM |
Re: Verteez Smartrap build May 09, 2014 05:34PM |
Re: Verteez Smartrap build May 09, 2014 09:51PM |
Re: Verteez Smartrap build May 10, 2014 05:21AM |
Re: Verteez Smartrap build May 10, 2014 05:57AM |
verteez
Regpye,
So, you say that I should adjust the voltage on the stepper drivers, or again change the microstepping?
My current microstepping is 106.10 from 48mmm motor 1.8 degree, 200 turns, 0.30mm fishing line and 4.5 motor shaft.
Only the bearing holder was printed on this tepup, rest was before on other setting(probably wrong and too less or too much)
Re: Verteez Smartrap build May 10, 2014 06:42AM |
Re: Verteez Smartrap build May 10, 2014 02:00PM |
Re: Verteez Smartrap build May 11, 2014 12:46AM |
verteez
No, I havent checked that, how to do this?
Right now Im changing the steps per mm with new math, and results are just ideal.
Yes, I have heatsinks on the stepper drivers, and they dont look like need to have a fan.
Re: Verteez Smartrap build May 11, 2014 02:08PM |
Re: Verteez Smartrap build May 11, 2014 02:26PM |
Re: Verteez Smartrap build May 11, 2014 06:13PM |
Re: Verteez Smartrap build May 12, 2014 04:55AM |
Re: Verteez Smartrap build May 12, 2014 12:51PM |
Re: Verteez Smartrap build May 13, 2014 04:47AM |
