Re: Verteez Smartrap build May 13, 2014 04:53AM |
verteez
Hey guys!
I have question to you all. Im in middle of printing no servo Jhead mount, and I wanted to ask how to use it when it will be done. I mean, after compiling the marlin, what then? Do I need to change something, set it somehow like before to work? Or just leave it and watch the magic?
Kamil.
Re: Verteez Smartrap build May 13, 2014 05:14AM |
regpye
verteez
Hey guys!
Kamil.
If you can be a little patient, I will have a specially prepared version of Marlin for the SmartRap with no servo.
I am using it now, however it has a small bug that needs to be fixed.
I can give you a copy of the one I am using now if you can't wait a few days, you will just need to make sure that the head is above the build plate when using a G28, the fix will do this automatically.
I am using it on Printrboards, so the only thing you would need to change apart from your own settings would be the board number from 81 to 33.
Re: Verteez Smartrap build May 13, 2014 01:38PM |
Re: Verteez Smartrap build May 14, 2014 01:16PM |
It was clean..|
Re: Verteez Smartrap build May 14, 2014 07:08PM |
verteez
What's new.
Ok, I have assembled the hotend and extruder again today. Extruder works fine, but not the nozzle.. I have started the print of J-head mount....and nozlle clogged after one hour, again?! How? WhyIt was clean..
Clean the nozzle by burning the old filament out. Hold the nozzle over a gas flame and let it get hot, but not too hot that it gets red. The filament will burn away and then when you wash in water it will be very clean.
I have lovered the current on extruder stepstick, will try also to lower up temp(now was 200C) and lower the filament flow in RH.
But for now I must wait again for the clean nozzle.
Anny ideas, or tips?
Also, what can I do to filament comming out of the nozzle to not sticking to it? Filament is curling and doing only mess, but when I remove it from nozzle, then it flow nice and straight for some time.
Re: Verteez Smartrap build May 18, 2014 04:45PM |
Re: Verteez Smartrap build May 23, 2014 08:11AM |
Re: Verteez Smartrap build May 23, 2014 08:51AM |
and with the right marlin ( with a little hack i did) , I have perfectly plane prints. This hack add an offset to the last probe point ( because of the bending) . It's just a number to adjust to your build and it works perfectly for me ? I know purists would say it's software going after hardware problems, but .. well i'm not purist
And remember, the all autolevelling systems that everyone is going after IS a software system to recover from hardware problem ( plate not perfectly aligned ).|
Re: Verteez Smartrap build May 23, 2014 09:09AM |
Re: Verteez Smartrap build May 23, 2014 09:28AM |
verteez
Hi Smartfriendz,
It would be nice to receive the part, but also Regpye has offered his help.
I will try to glue it somehow and if not, then ask for print. Now it's drying of glue on table..
Can you share your Marlin?
Because I have terrible problems with my Z offset, thats why I have tried to eliminate the bending, which now is acceptable.
I just cant calibrate the nozzle height propetly. After setting the offset the nozzle is always in wrong height at diffrent bed places. Where bed is lower, the nozzle is higer, where bed is higer the nozzle is to low and dragg the bed. I just cant do it, and don't know why. I will post some video in next hour, so you will see the problem.
Also i can't, don't know why, change the point of probing. I change them in Marlin, but they are always the same when I run the print..
Re: Verteez Smartrap build May 23, 2014 09:57AM |
Re: Verteez Smartrap build May 23, 2014 10:03AM |
madmike8
Considering your extruder had broke once too, sounds like your suppliers parts are a little suspect.
Reg and Serge are good people to be so helpful.
I use the servo version of the Smartrap, and I don't have the bed probing issues that the servoless version has. I did have to constantly adjust the Z offset till I fixed the loose Z nut and loose bearing issues. Now it seems pretty stable again.
Now I regret it..|
Re: Verteez Smartrap build May 23, 2014 10:34AM |
Re: Verteez Smartrap build May 23, 2014 11:03AM |
Re: Verteez Smartrap build May 23, 2014 05:07PM |
smartfriendz
oops. too bad verteez,
If you can't find anyone, i'm going to print you a new plate_x.. no problem.
I just wonder why you guys want absolutely no bend ? I have here 4 smartraps in production ( to make smartrapsand with the right marlin ( with a little hack i did) , I have perfectly plane prints. This hack add an offset to the last probe point ( because of the bending) . It's just a number to adjust to your build and it works perfectly for me ? I know purists would say it's software going after hardware problems, but .. well i'm not purist
Re: Verteez Smartrap build May 23, 2014 08:52PM |
BackEMF
Hi Kamil,
Regpye's Marlin works fine for me. have you tried my config settings?
My config files are in my Build thread if you need them.
Serge,
The autoprobe pressure on the edge of the bed is the main flex problem for me aswell. Specially with the grid auto level. (then it bends 3 times) Though i solvet that by not probing over to far over the Y rods.
I probe X no furter then 70, right on top of the rods and that fixes the whole issue for me.
The X and Z are in my case rigid enough.
I'm going to test Regpye's hotend, he is making it now. I'm not going to print much until then, i dont want to break my hacked extruder before i've printed a new one.
I'm looking if i can write some documentation, though it's hard to figure out what makes sense to document now there are so many variations.
Re: Verteez Smartrap build May 23, 2014 08:56PM |
smartfriendz
Regpye ? Let's print from the cheapest place to ship ? what do you think ?
But here i will certainly print the standard version , as i have them in sdcard in production .
Re: Verteez Smartrap build May 24, 2014 05:14AM |
you're fast indeed. |
Re: Verteez Smartrap build May 24, 2014 05:49AM |
Re: Verteez Smartrap build May 24, 2014 06:22AM |
verteez
Wow, thanks Regpye!!
BackEMF, also thanks for your marlin config file.. It's working, but I have still some problems with bed leveling. The nozzle is still not moved like it should be, about 1mm. Also, I can't change probe point on bed. After flashing Marlin with new ones, the printer again and again and again use the same old ones. So probably that's why me bed level isn't correct.
Thanks Smartfriends for help, but RegPye is fast like a lightning bolt
Kamil.
Re: Verteez Smartrap build May 24, 2014 06:59AM |
Re: Verteez Smartrap build May 24, 2014 08:30AM |
Re: Verteez Smartrap build May 25, 2014 03:14PM |
Re: Verteez Smartrap build May 27, 2014 09:49AM |
Re: Verteez Smartrap build May 27, 2014 01:36PM |
Re: Verteez Smartrap build May 27, 2014 02:12PM |
Re: Verteez Smartrap build May 27, 2014 02:46PM |
Re: Verteez Smartrap build May 27, 2014 02:53PM |
Re: Verteez Smartrap build May 27, 2014 06:43PM |
verteez
Im using the "grid" mode of probing. I will try and set the 3 point, maybe it will change something.
_______________________________
Well, it hasn't changed annything. It looks like the data took while probing are inverted. :/
Re: Verteez Smartrap build May 28, 2014 07:36AM |
regpye
verteez
Check two things.
1. Have you got your limit switch working correctly, it sounds like it may be open instead of closed. Or a broken wire maybe.
2. Is the Z motor set in reversed direction?
