Re: Verteez Smartrap build September 21, 2014 07:26PM |
verteez
Now I know that its a tricki one
Yes, im using the fan for genie hotend, and the fan for the nozzle. But I havent printed yet Your duct.
Right now Im using Cura 14.07 for some time, and I just love it. It just was giving me the better results than RH with less effort.
Yes, right now retracion is like this: Speed 45mm/s, distance 5mm, and in the expert settings nothing changed.
I was printing Maori with 0.14mm layer height, 0.3mm nozzle, temp 204C, shell thickness 0.6, bottom/top thickness 0.6, initial layer thickness 0.2, infil 25%, speed 40mm/s
regpye
The Maori is a tricky one to print and is very good for testing.
Are you using a fan?
What software did you use for slicing?
Are you using retract?
Re: Verteez Smartrap build September 23, 2014 11:49PM |
Re: Verteez Smartrap build September 24, 2014 05:30AM |
BackEMF
Very nice remix Verteez!
Congrats.
What about adding something like this?
https://sites.google.com/site/3dprinterlist/home/mechanics/simple-anti-backlash-system
Not that backlash is a problem, but i like the simplicity of that antibacklash system hehehe
Re: Verteez Smartrap build September 24, 2014 11:19PM |
Re: Verteez Smartrap build October 01, 2014 04:16PM |
22:00:14.143 : 22:00:14.143 : Bed Level Correction Matrix: 22:00:14.143 : 1.00 0.00 0.00 22:00:14.147 : 0.00 1.00 0.01 22:00:14.147 : -0.00 -0.01 1.00 22:00:18.533 : echo:endstops hit: Z:-0.61 22:01:58.593 : Eqn coefficients: a: 0.00 b: 0.01 d: 3.74 22:01:58.594 : planeNormal x: -0.00 y: -0.01 z: 1.00 22:01:58.594 : 22:01:58.598 : Bed Level Correction Matrix: 22:01:58.598 : 1.00 0.00 0.00 22:01:58.598 : 0.00 1.00 0.01 22:01:58.598 : -0.00 -0.01 1.00 22:02:03.001 : echo:endstops hit: Z:-0.58 22:03:58.461 : Eqn coefficients: a: -0.00 b: 0.01 d: 3.76 22:03:58.462 : planeNormal x: 0.00 y: -0.01 z: 1.00 22:03:58.462 : 22:03:58.465 : Bed Level Correction Matrix: 22:03:58.465 : 1.00 0.00 -0.00 22:03:58.466 : 0.00 1.00 0.01 22:03:58.466 : 0.00 -0.01 1.00 22:04:02.844 : echo:endstops hit: Z:-0.76 22:06:23.937 : Eqn coefficients: a: -0.00 b: 0.01 d: 3.73 22:06:23.937 : planeNormal x: 0.00 y: -0.01 z: 1.00 22:06:23.941 : 22:06:23.941 : Bed Level Correction Matrix: 22:06:23.941 : 1.00 0.00 -0.00 22:06:23.941 : 0.00 1.00 0.01 22:06:23.944 : 0.00 -0.01 1.00 22:06:28.348 : echo:endstops hit: Z:-0.64
Re: Verteez Smartrap build October 05, 2014 06:52PM |
Re: Verteez Smartrap build October 05, 2014 07:11PM |
verteez
I have small problem with my marlin again..
Every time I run g29 command I got diffrent Z offset read :/ But my bed is for sure always in the same position, and nothing is changing the nozzle position.
What can cause this?
here are last 4 probes22:00:14.143 : 22:00:14.143 : Bed Level Correction Matrix: 22:00:14.143 : 1.00 0.00 0.00 22:00:14.147 : 0.00 1.00 0.01 22:00:14.147 : -0.00 -0.01 1.00 22:00:18.533 : echo:endstops hit: Z:-0.61 22:01:58.593 : Eqn coefficients: a: 0.00 b: 0.01 d: 3.74 22:01:58.594 : planeNormal x: -0.00 y: -0.01 z: 1.00 22:01:58.594 : 22:01:58.598 : Bed Level Correction Matrix: 22:01:58.598 : 1.00 0.00 0.00 22:01:58.598 : 0.00 1.00 0.01 22:01:58.598 : -0.00 -0.01 1.00 22:02:03.001 : echo:endstops hit: Z:-0.58 22:03:58.461 : Eqn coefficients: a: -0.00 b: 0.01 d: 3.76 22:03:58.462 : planeNormal x: 0.00 y: -0.01 z: 1.00 22:03:58.462 : 22:03:58.465 : Bed Level Correction Matrix: 22:03:58.465 : 1.00 0.00 -0.00 22:03:58.466 : 0.00 1.00 0.01 22:03:58.466 : 0.00 -0.01 1.00 22:04:02.844 : echo:endstops hit: Z:-0.76 22:06:23.937 : Eqn coefficients: a: -0.00 b: 0.01 d: 3.73 22:06:23.937 : planeNormal x: 0.00 y: -0.01 z: 1.00 22:06:23.941 : 22:06:23.941 : Bed Level Correction Matrix: 22:06:23.941 : 1.00 0.00 -0.00 22:06:23.941 : 0.00 1.00 0.01 22:06:23.944 : 0.00 -0.01 1.00 22:06:28.348 : echo:endstops hit: Z:-0.64
I have been using RegPye Marlin version with Roxy's enchanced probing, and normal Marlin from Smartfriendz github. I was using it with EEprom turned on, and disabled. The result is always the same- floating offset.
Today I have been using grid method, because the 3 point also was giving me diffrent results. Also I couldn't compile RegPye marlin with 3 point probe.
Anny ideas?
Re: Verteez Smartrap build October 06, 2014 09:18AM |
regpye
verteez
Anny ideas?
I am now using a different version again, it is a mix of the earlier version and some later additions.
I use it in 3 point mode because that is all I every found necessary.
I made a small change to the pins.h file, nothing really important, but I had a RAMPS board that didn't work on the heated bed thermistor (fault with that particular board) so I changed the bed thermistor to be in the second hotend thermistor place instead to get this board working. I never changed it back again for the next boards I used as I found that the position for plugging in the heated bed thermistor was easier for me in the new place.
As I use this same version of Marlin for all my machines, not just SmartRaps, I have the servo section of the RAMPS board used as that is already setup and works wonderfully as standard.
If you want a copy of the Marlin I am using now, let me know and I will post it.
