BackEMF's SmartRap 0.4.7 build April 24, 2014 07:17AM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 08:11AM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 08:36AM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 12:17PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 12:20PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 01:36PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 02:28PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 03:02PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 03:04PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 03:34PM |
BackEMF
[www.ebay.com]http://www.ebay.com/usr/ohpakron
Is the only source for J-head lite at this moment
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 03:50PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 05:36PM |
max was 30 , to make a good 20 printable. |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 06:44PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 08:00PM |
Re: BackEMF's SmartRap 0.4.7 build April 24, 2014 08:51PM |
Re: BackEMF's SmartRap 0.4.7 build April 27, 2014 07:26PM |
Re: BackEMF's SmartRap 0.4.7 build April 27, 2014 07:31PM |
Re: BackEMF's SmartRap 0.4.7 build April 27, 2014 07:35PM |
Re: BackEMF's SmartRap 0.4.7 build April 27, 2014 09:23PM |
Re: BackEMF's SmartRap 0.4.7 build April 27, 2014 09:32PM |
madmike8
I wanted to add this to my thread for future reference on my mirrored Y problem that was fixed.
I'm using Marlin
To Change the motor direction in Configuration.h change the
const bool Y_MIN_ENDSTOP_INVERTING to true
const bool Y_MAX_ENDSTOP_INVERTING to false
#define INVERT_Y_DIR from true to false
Then you need to Change your Homing Direction by changing
#define Y_HOME_DIR from -1 to 1
Now if you try it, it might not home, so you need to remark (add //) to the beginning of this line
#define DISABLE_MAX_ENDSTOPS
Then in pins.h under the Arduino Mega pin assignment
There are 2 places to set the Y Pins one is under #if MOTHERBOARD == 77
But we are using the RAMPS Motherboard, so we need to change the ones under the #else statement.
change
#define Y_MIN_PIN change the 14 to 15
And
#define Y_MAX_PIN change the 15 to 14
Hopefully this fixes your Y Mirrored issues...
Re: BackEMF's SmartRap 0.4.7 build April 28, 2014 04:02AM |
lol .|
Re: BackEMF's SmartRap 0.4.7 build April 28, 2014 08:42AM |
Re: BackEMF's SmartRap 0.4.7 build April 28, 2014 10:41AM |
Re: BackEMF's SmartRap 0.4.7 build April 28, 2014 09:37PM |
Re: BackEMF's SmartRap 0.4.7 build April 29, 2014 12:30AM |
Re: BackEMF's SmartRap 0.4.7 build April 29, 2014 12:52AM |
BackEMF
10mm shaft 0.3 string:
3.1415*(10+0.3)=32.35745
200*16/32.35745=98.895308499 or 98.89
Configuration.h
#define motors1840 // version motors 1.8 degres, 40mm long . this one has a shaft adaptor and changes steps
#define DEFAULT_AXIS_STEPS_PER_UNIT {98.89,98.89,4000,83} // smartrap : version 1.8degv{194,194,4000,85} robotdigg.shaft adaptor,fishline big
so this should be ok now, finetuning comes later
But now i need to configure Cura and set up autoleveling
And there is still some odd endstop behaviour, sometimes the firmware doesn't react to endstops. I measured the endstops and electrically they are still ok so what can still be wrong.
If the smartrap homes should it home @ the endstops or does home to an offset position?
and what are the correct commands to manually test this?
G21;Metric! G28 X0 Y0 ;Home X and Y G29 ;Probe bed G90; Set absolute coordinates G1 Z5 F3000; Lift Z and get out of the bed after probe G1 X10 Y10 F3000 ; Move to front left corner G1 X120 Y120 Z10 ;Move cross bed - Lift Z 5 mm more G1 X10 Y120 Z20 ; Move along the back of the bed to the left - Move Z up 10 mm G1 X70 Y10 Z5 ; Move ~center front - Z down 15 mm G1 X70 Y70 Z1 ; Move ~ X/Y center and bring Z to 1 mm from bed.
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
Re: BackEMF's SmartRap 0.4.7 build April 29, 2014 09:16AM |
G21 ; metric is good! G90 ; absolute positioning T0 ; select new extruder G28 ; go home G29 ; auto bed level G92 E0 ; set extruder home M104 S195.0 ; set temperature to 195.0 G1 X20 Y20 F500 ; move away from 0.0, to use the same reset for each layer
Re: BackEMF's SmartRap 0.4.7 build April 29, 2014 10:26AM |
Re: BackEMF's SmartRap 0.4.7 build April 29, 2014 10:50AM |
Re: BackEMF's SmartRap 0.4.7 build April 29, 2014 11:02AM |
madmike8
Mark, your link is missing an e in free... I just signed up over there. I've never used a CAD package in my life, but that's what I want to do, and part of the point of owning a printer... So expect lots of stupid questions over there.
