Smartrap evolution, improvements... April 30, 2014 10:56AM |
Re: Smartrap evolution, improvements... April 30, 2014 04:18PM |
Re: Smartrap evolution, improvements... April 30, 2014 04:46PM |
There can't be simper solution
Re: Smartrap evolution, improvements... April 30, 2014 05:29PM |
Re: Smartrap evolution, improvements... April 30, 2014 06:30PM |
Re: Smartrap evolution, improvements... April 30, 2014 06:31PM |
Re: Smartrap evolution, improvements... April 30, 2014 07:21PM |
Re: Smartrap evolution, improvements... May 01, 2014 01:20AM |
Re: Smartrap evolution, improvements... May 01, 2014 01:56AM |
Re: Smartrap evolution, improvements... May 01, 2014 02:29AM |
Re: Smartrap evolution, improvements... May 01, 2014 08:26AM |
All with the rack&pinions, we're on the good way to the all printed structure . Yes, i'm thinking about that too .. hehe. |
Re: Smartrap evolution, improvements... May 01, 2014 08:27AM |
Re: Smartrap evolution, improvements... May 01, 2014 08:42AM |
There's enough other reprap projects doing wonderful job with aluminium frame, metal frame, etc...
Re: Smartrap evolution, improvements... May 01, 2014 09:49AM |
Re: Smartrap evolution, improvements... May 01, 2014 11:48AM |
Re: Smartrap evolution, improvements... May 01, 2014 12:01PM |
Re: Smartrap evolution, improvements... May 01, 2014 01:32PM |
markstephen
A sneak-peek at the bushing plate. Hope to be testing later on today / tomorrow. We'll see how it goes.
Mark
[attachment 31964 Bushing_Plate1.png]
[attachment 31965 Bushing_Plate2.png]
Re: Smartrap evolution, improvements... May 01, 2014 03:02PM |
TCase
markstephen
Mark
You need the mount for the limit switch.
Woops, wasn't paying attention.
But it might be worth trying to incorporate the stepper mounting screws. If it could be done it would be 1l less screw (and nut) and wouls gaurantee the bearings didn't wobble about.
Re: Smartrap evolution, improvements... May 01, 2014 08:22PM |
Re: Smartrap evolution, improvements... May 02, 2014 01:00AM |
verteez
Personally, I really want to get the files of Geared extruder made by Regpye. Or if not, then will use some desigh from thingiverse
Re: Smartrap evolution, improvements... May 02, 2014 01:02AM |
verteez
Mark is right. The X axis bearing mouting is a week spot. Mine, ewen with not changing to 'no servo' bed probing were loose, and just popping out.
Will wait for some progras with it. Anny change to this will be good one.
Re: Smartrap evolution, improvements... May 02, 2014 03:03AM |
regpye
verteez
I have a left hand and a right hand version of the geared extruder, which would you like to use? Left hand has the exit on the left, right hand on the right.
It can be left, it can be also right. It's the direction told by facing printer prom front(hotend) or back?
Re: Smartrap evolution, improvements... May 02, 2014 07:16PM |
Re: Smartrap evolution, improvements... May 02, 2014 07:24PM |
Re: Smartrap evolution, improvements... May 02, 2014 07:31PM |
Re: Smartrap evolution, improvements... May 02, 2014 07:44PM |
Re: Smartrap evolution, improvements... May 02, 2014 08:00PM |
markstephen
i came up with what I think is a reasonable stop gap solution to the flexing problem and seems to be working well. It should hold me over until a more permanent solution can be conjured up. All i did was knock out a couple of made to fit C Clamps and feet to hold down the front of the holder. Works a treat...
I need to make a little adjustment before I upload the files, that is, if anyone is interested in them.
Mark
[attachment 32006 C_Clamp_Assembly.png]
[attachment 32008 C_Clamps_1.JPG]
[attachment 32009 C_Clamps_2.JPG]
Re: Smartrap evolution, improvements... May 02, 2014 08:19PM |
verteez
regpye
verteez
I don't know, both will be goodIt can be left, it can be also right. It's the direction told by facing printer prom front(hotend) or back?
Re: Smartrap evolution, improvements... May 02, 2014 10:56PM |
Re: Smartrap evolution, improvements... May 02, 2014 11:48PM |
madmike8
Regpye, I can't wait till you have those tested and post them. Really Nice.
Mark, can you make bearings that just bolt down thru the stepper holes?
