Re: Smartrap evolution, improvements... June 08, 2014 07:10PM |
Re: Smartrap evolution, improvements... June 08, 2014 08:06PM |
Re: Smartrap evolution, improvements... June 08, 2014 08:09PM |
madmike8
Yup, with the quick connect.
regpye
No, mine is 2.75" or 65mm from tip of nozzle to the end of the cold end, so it is not too different from the standard J-head.
Mine also has a few more parts than the J-head, those are to stop the heat travel.
Source files will be available when I get time to put them up on my website.
Save a bit of time is the least I could do...
Thanks Mark!
Re: Smartrap evolution, improvements... June 09, 2014 05:37AM |
Re: Smartrap evolution, improvements... June 09, 2014 04:50PM |
BackEMF
i'm wondering, has anyone already printed flexible PLAon the SmartRap?
And what about printing normal PLA and then soften it up chemically?
Re: Smartrap evolution, improvements... June 09, 2014 04:58PM |
Re: Smartrap evolution, improvements... June 09, 2014 06:16PM |
verteez
Unfortunatelly is expensive as hell in Poland :< anny cheap alternatives for flexible materials?
Re: Smartrap evolution, improvements... June 10, 2014 03:59AM |
Re: Smartrap evolution, improvements... June 10, 2014 04:30PM |
It's moving all the time with the auto level and get old very fast.
Re: Smartrap evolution, improvements... June 10, 2014 04:46PM |
Re: Smartrap evolution, improvements... June 11, 2014 01:47AM |
Re: Smartrap evolution, improvements... June 11, 2014 02:04AM |
Do you mean turn the X plate around 180 degrees so the top is now the bottom?Quote
ZeAllan
Quick thought: If the plateX could be "turned on its head", so that the Z rod bearings were to sit down beside the motor instead of partly above the carriage, wouldn't you be able to get a cm or two more print height with the same Z rods without stability suffering?
/Allan
Re: Smartrap evolution, improvements... June 11, 2014 04:06AM |
regpye
ZeAllan
/Allan
Re: Smartrap evolution, improvements... June 11, 2014 04:21AM |
ZeAllan
regpye
ZeAllan
/Allan
More like a redesign that moves the holders for the Z bearings down below to top of the plate. Turning it 180 degrees might be the easiest way to do it in order to keep the plate easily printable, but it would probably require the "offset" of the plate to be higher in order to keep the head above the plate, so that would defeat the purpose (and having the motor on top feels wrong somehow).
On the other hand, if it were possible to redesign the hotend holder to have the head a bit higher up, that might give the same effect...
/Allan
Re: Smartrap evolution, improvements... June 12, 2014 06:19AM |
verteez
markstephen
I see their using carburetor cleaner to soften the PLA.
smartfriendz
I have hard time to follow everything, 0.4.9 coming out, Z GT2 in place of the M5 thread : I'm tired of the noise of this threaded rod
Re: Smartrap evolution, improvements... June 12, 2014 11:39AM |
BackEMFQuote
smartfriendz
Much respect for keeping up this good, i also find it hard to keep up. Z GT2 sounds VERY interesting. Z-whining is also getting on my nerves (I can't print at night because of it).
Re: Smartrap evolution, improvements... June 12, 2014 07:10PM |
Re: Smartrap evolution, improvements... June 12, 2014 07:30PM |
markstephen
BackEMFQuote
smartfriendz
What? What noise / "Z-whining"? My threaded rod is quiet as a mouse and the stepper does not make any more noise than the others. No objection to a belt driven Z, just wondering where all this noise is coming from.
Mark
Re: Smartrap evolution, improvements... June 12, 2014 10:32PM |
Re: Smartrap evolution, improvements... June 12, 2014 10:37PM |
Re: Smartrap evolution, improvements... June 12, 2014 11:00PM |
Re: Smartrap evolution, improvements... June 13, 2014 01:00AM |
smartfriendz
lot of development everywhere on the smartrap side lately. I have hard time to follow everything, i'm sorry for that !
On my side, i try to integrate what i read or see here and there. So there is a 0.4.9 coming out ( already on github and visualisation there : [sketchfab.com] ).
it's just evolution :
- separation of extruder : now base plate is naked and we have krisdaniels ( a little modified) direct drive as default. The main reason is to have a possible adjustment ( screw) to fit different gear drives and also the space to put a geared extruder without having to hack the base_plate. ( more options).
- GT2 integration complete ( with tensioners , i can't have nice printed gt2 holders integrated with the current model ).
- some plateX redesign to loos weight .
Next work : Z GT2 in place of the M5 thread : I'm tired of the noise of this threaded rodIt's moving all the time with the auto level and get old very fast.
thank you all again for being so active with this project ! It's amazing
Re: Smartrap evolution, improvements... June 13, 2014 11:04AM |
Actually, it's even less bended than before. |
Re: Smartrap evolution, improvements... June 13, 2014 07:35PM |
smartfriendz
Re: Smartrap evolution, improvements... June 13, 2014 11:20PM |
Re: Smartrap evolution, improvements... June 13, 2014 11:45PM |
markstephen
1/16 step should be fine. That's 0.0125 mm per step, or 16 Esteps to make a 0.2 mm (20 micron) layer height. That's not bad. Sure, 1/32 steps would give you more resolution, but is it really needed?
Mark
Re: Smartrap evolution, improvements... June 13, 2014 11:58PM |
Re: Smartrap evolution, improvements... June 19, 2014 09:36PM |
markstephen
Mark
Re: Smartrap evolution, improvements... June 20, 2014 12:08PM |
Re: Smartrap evolution, improvements... June 20, 2014 01:02PM |
You probably have a dual holder for the Smartrap already designed up and your head and your fingers are twitching over your mouse waiting to put those ideas in to FreeCAD... I'll mail you a spare Jhead-Lite thanks to Regpye. Come on... You know you want too... I think I have some spare PTFE tube too...
