Reg Pye's SmartRap build May 13, 2014 09:48AM |
Re: Reg Pye's SmartRap build May 13, 2014 12:08PM |
Re: Reg Pye's SmartRap build May 13, 2014 03:49PM |
Re: Reg Pye's SmartRap build May 13, 2014 04:34PM |
Re: Reg Pye's SmartRap build May 13, 2014 08:12PM |
Re: Reg Pye's SmartRap build May 26, 2014 12:17PM |
smartfriendz
haha i would just say : wow
Reaaaally a nice work regpye ! i can be only impressed .
Nice work on the plate_x . I would easy integrate it in main kit
Re: Reg Pye's SmartRap build May 27, 2014 07:15AM |
Re: Reg Pye's SmartRap build May 27, 2014 09:20AM |
Re: Reg Pye's SmartRap build May 27, 2014 11:02AM |
Re: Reg Pye's SmartRap build May 27, 2014 06:46PM |
verteez
Nice one!
Im curious how it's gonna work For me looks really similar to Printrbot
Re: Reg Pye's SmartRap build May 28, 2014 06:34AM |
verteez
Nice one!
Re: Reg Pye's SmartRap build May 28, 2014 07:43AM |
Re: Reg Pye's SmartRap build May 28, 2014 07:59AM |
verteez
Yes, I mean by similar only the rods setup.
Overal really nice look, I think that I will maybe do one like this for myself
Nice prints, what's the print output?
Re: Reg Pye's SmartRap build May 28, 2014 08:02AM |
BackEMF
Looks great Reg,
I think Cliff could use this X-Z axis plate on his wooden Smartrap.
Re: Reg Pye's SmartRap build May 28, 2014 02:17PM |
Re: Reg Pye's SmartRap build May 28, 2014 06:14PM |
Re: Reg Pye's SmartRap build June 14, 2014 08:27PM |
Re: Reg Pye's SmartRap build June 15, 2014 05:54AM |
Re: Reg Pye's SmartRap build June 15, 2014 12:32PM |
Re: Reg Pye's SmartRap build June 15, 2014 08:22PM |
ZeAllan
Impressive! :-)
When looking at the Z belt, it reminds me a little bit about H-bots ("crossbot"?) Just wondering if it would be feasible to use something like that principle here, so that all motors could be moved to either top or bottom, giving less weight to lift?
/Allan
Re: Reg Pye's SmartRap build June 15, 2014 08:29PM |
Cliff Mellangård
This is impressive
I like the design a lot and is it possible to get all stl files for this version ?
Or wath would you want for a complete kit to Sweden
Jaw dropping simplicity of the design
Re: Reg Pye's SmartRap build June 16, 2014 03:16AM |
regpye
ZeAllan
/Allan
Can you send me a reference of the "crossbot" so I can see what you mean? I guess there are many ways to do this, but this way I thought was easiest for me to do. Not tested yet, so we will see how it goes.
Re: Reg Pye's SmartRap build June 16, 2014 06:21AM |
Re: Reg Pye's SmartRap build June 17, 2014 04:23AM |
Re: Reg Pye's SmartRap build June 18, 2014 11:44PM |
smartfriendz
wow impressive regpye ( as usual with you .
It's cool you test the z with belt. I didn't have time to do it here with the production . Thx for that
I will try also your all build when it's available. it's really a nice work ! I can't say anything else than congrats. I say often i take ideas from you as you go forward with the (re) design of this project and integrate in the updates. thx again for that !
I hope it goes well ?
About the X+Z with belt, i remember i've seen some builds doing that a long time ago. You can indeed make a belt arrangement so the X axis can go up and down without changing the total length of the belt. It needs a firmware correction , as when you go up or down, the X will move too, so you need to correct.. But i remember it was working well ( I think it was small aluminium printer looking like a cnc ... 2 or 3 years ago. i can't remember the name).
keep the good work
On my side, i was thinking exactly about the regpye solution for the Z.. Now we nee to find a way to prevent the head from crashing on the glass if power is suddenly off ! For the rest, it should be better with the GT2.
Re: Reg Pye's SmartRap build June 19, 2014 01:59AM |
Re: Reg Pye's SmartRap build June 19, 2014 02:24AM |
markstephen
The Z does not need speed, and there is "some" resistance in the steppers even when there is no power. I would think that gearing it down, either with a belt/pulley or gears, the reduction would allow the no-power holding torque of the stepper to stop the motor from turning.
Mark
Re: Reg Pye's SmartRap build June 19, 2014 04:50AM |
Re: Reg Pye's SmartRap build June 19, 2014 05:19AM |
Re: Reg Pye's SmartRap build June 19, 2014 07:38AM |
