Re: Reg Pye's SmartRap build June 19, 2014 10:39AM |
Re: Reg Pye's SmartRap build June 19, 2014 10:47AM |
smartfriendz
lot of work here again regpye, impressive as usual![]()
the new geared extruder seems more light ? cool to try i think. I just changed to separated extruder so we can choose between direct drive or .... maybe this one ?? thank you .
About the new system for Z GT2, I would love to try it ( i would for now integrate on the main model to minimise changes for now ). How does it work ? I mean the break system ?
thx
Re: Reg Pye's SmartRap build June 19, 2014 10:49AM |
Aze_aze_aze
It looks like there is just more friction now on the Z belt, to avoid the fall. I'm not sure.
Re: Reg Pye's SmartRap build June 19, 2014 10:12PM |
Re: Reg Pye's SmartRap build June 23, 2014 09:34PM |
Re: Reg Pye's SmartRap build June 23, 2014 10:16PM |
Re: Reg Pye's SmartRap build June 23, 2014 11:02PM |
MelT
This group is lucky to have you sir, for constantly trying things which not all of us can afford to do. :-)
If there's one thing I wish someone tries though, it would be the fixed X rods like the reprap ormerod. Hehe
Re: Reg Pye's SmartRap build June 24, 2014 02:51AM |
Re: Reg Pye's SmartRap build June 24, 2014 03:02AM |
BackEMF
Reg please share the STL's for the X and Z i'd like to give this a try.
Also i see an option to use the same parts of the X axis to be used on the Y axis (as a carriage like Cliffs wooden SmartRap)
then it's a matter of printing one file 2 times. That also would make production a tiny bit simpler?
Re: Reg Pye's SmartRap build June 28, 2014 04:48AM |
BackEMF
Re: Reg Pye's SmartRap build June 29, 2014 03:05AM |
Re: Reg Pye's SmartRap build August 08, 2014 09:02PM |
Anonymous User
Re: Reg Pye's SmartRap build August 08, 2014 10:24PM |
Re: Reg Pye's SmartRap build August 08, 2014 10:45PM |
napalmvictory
Hey Reg. The vertical support idea is good. I've had a little success with 1/16" wire rope as opposed to structural support. Could be applicable to your predicament.
Anonymous User
Re: Reg Pye's SmartRap build August 08, 2014 11:15PM |
Re: Reg Pye's SmartRap build August 09, 2014 03:39AM |
napalmvictory
Not so much a design as it is a concept. Stabilizing the Z axis with cables. Might add a couple inches to the Z height on a number of printers if it can be properly implemented.
Re: Reg Pye's SmartRap build August 13, 2014 07:53AM |
Re: Reg Pye's SmartRap build August 14, 2014 06:52AM |
