Z axis wobbing large May 25, 2014 04:41PM |
Re: Z axis wobbing large May 25, 2014 06:34PM |
Re: Z axis wobbing large May 25, 2014 09:21PM |
Re: Z axis wobbing large May 25, 2014 11:25PM |
solarprism
And it seems that due to this, the bolt is being grind down to the extent that it slipped on the thread rods.
Re: Z axis wobbing large May 26, 2014 12:02AM |
markstephen
Reading that again, I'm thinking he means nut, not bolt -
solarprism
So it sounds like he has a rather crappy threaded rod, soft nut, and or no lube on the threaded rod. I'v just used a little petroleum jelly as I can't seem to be able to fine my silicon grease anywhere.
Re: Z axis wobbing large May 26, 2014 12:52AM |
Re: Z axis wobbing large May 26, 2014 07:14AM |
Re: Z axis wobbing large May 26, 2014 09:19AM |
Re: Z axis wobbing large May 26, 2014 12:11PM |
BackEMF
An IONX nut on an INOX rod will wear down both the nut and the rod, so that's why i thought it's better to use a bronze nut? The oil in the bronze will lubricate and only the nut wears down. Though i wonder how fast Solarprism managed to wear down that nut. Is there maybe another issue that causes that nut to wear down faster?
What about using a nylock locknut? (or is that what Regpye meant with acetyl nut?)
Re: Z axis wobbing large January 22, 2016 06:12AM |
