How fast can your smartrap print? June 02, 2014 09:32PM |
Re: How fast can your smartrap print? June 02, 2014 10:19PM |
Re: How fast can your smartrap print? June 02, 2014 10:25PM |
Re: How fast can your smartrap print? June 02, 2014 11:48PM |
Re: How fast can your smartrap print? June 03, 2014 02:30AM |
There's a depot nearby that opened recently (claiming to be a builders one stop shop) but they only have 25mm length bolts
I won't be scratching my head anymore trying to troubleshoot. That's probably all my motor could give on a direct drive configuration. |
Re: How fast can your smartrap print? June 03, 2014 03:19AM |
MelT
Thanks guys!
If I can get mine to print even at 30mm/s reliably, I will be very happy.
Unfortunately, I'm still getting that kickback on my extruder motor. Worse, I don't see a pattern on when it occurs. Sometimes during infill, and sometimes on perimeters. At times, it happens a few times in a row with only seconds in between and sometimes, just once every few minutes. I dialed down my flow rate to 85% and I get significantly less kickback but it still happens. I don't want to go less because I sometimes see gaps in my prints already. Filament is also from robotdig and needs 225-230 degrees. Diameter of filament ranges from 1.6 to 1.65mm so I have 1.6mm set in slicer. I will try other suppliers when I run out of PLA.
Another thing I tried was to step up my stepper driver a bit. About a quarter turn clockwise compared to the XYZ setting. I don't want to go any further because my extruder motor gets very hot to the touch after around 30 mins.
I should try your geared extruder, regpye. I think that will solve my extruder motor problem. In fact, I already tried to buy the bolt but just like during my build, I'm having a hard time finding a store that sells bolts in metric system.There's a depot nearby that opened recently (claiming to be a builders one stop shop) but they only have 25mm length bolts
At least I know that 20mm/s is not too slow.I won't be scratching my head anymore trying to troubleshoot. That's probably all my motor could give on a direct drive configuration.
By the way, what size of tap is best for the hobbed bolt? 8mm? 5mm? 4mm?
Re: How fast can your smartrap print? June 03, 2014 03:47AM |
I wish I could make another printer someday.
Who knows? I might drop by your showroom if it's open to public hehehe.
Re: How fast can your smartrap print? June 03, 2014 04:28AM |
Re: How fast can your smartrap print? June 03, 2014 04:47AM |
Re: How fast can your smartrap print? June 03, 2014 12:53PM |
Re: How fast can your smartrap print? June 03, 2014 06:54PM |
Re: How fast can your smartrap print? June 03, 2014 08:54PM |
Re: How fast can your smartrap print? June 10, 2014 04:59AM |
. Not a problem since I plan to mount it externally anyway using my spare stepper motor. I couldn't find a tap that is being sold individually so I just used the MK8 hobbed drive. |
Re: How fast can your smartrap print? June 10, 2014 10:22AM |
MelT
I hope you guys can come back here and share your nozzle diameter. I believe that affects the maximum print speed which were not shared above. I'm asking becaue after trying the geared extruder, I'm still getting kickbacks.
I printed Regpye's geared extruder from smartrap's github. After 4 hours of printing, I noticed it was pointing the other way. Not a problem since I plan to mount it externally anyway using my spare stepper motor. I couldn't find a tap that is being sold individually so I just used the MK8 hobbed drive.
I thought it was the end of my extruder kickback problem but, lo and behold, it still happens. Normally during the first layer. Thinking that my nozzle is too close to the glass on my first layer, I adjusted the offset by 0.2mm and no more kickback so far but only on first layers. I still get it from time to time.
While it didn't cure the kickback, I must say that a geared extruder makes a difference in speed and consistency. I probably have a really bad filament to fix other print issues but I was able to go 40mm/s! Whohoo!
I might slow it down again when I need the absolute print quality but for printer parts and replacement parts, I don't really need top notch quality so I want to push the speed a little.
So why do I still get that kickback? The last thing I did was go extreme and adjusted my flow rate to 70%! It's going well so far without kickback at this setting but I'm wondering why my flow rate is way off that I had to turn it down that much.
My j-head was 0.3mm but I found a 0.5mm drill at an electronics store and used it to drill the nozzle. When I measured it with my cheap caliper, it turs out to be only 0.35mm diameter which I put as my nozzle diameter on slicer. I was hoping to make it at least 0.4mm to make prints a bit faster but even with 0.35mm nozzle, is it realistic to be able to print at 50mm/s?
Re: How fast can your smartrap print? July 01, 2014 04:25PM |
Re: How fast can your smartrap print? July 01, 2014 05:46PM |
duranza
Well, last night I had my printer going 100 mm/sec with Reg's geared extruder at 210c with very good finish and not missing any steps. This produced the best looking print from it to date. Very shiny and solid. This also got rid of all the stringing while moving to positions. The z rods do shake a little at this speed, and I had my retraction set to 0 afraid that I would strip the filament. I'll post a picture of the finished product tonight.
Re: How fast can your smartrap print? July 01, 2014 06:05PM |
Re: How fast can your smartrap print? July 01, 2014 06:36PM |
Re: How fast can your smartrap print? July 01, 2014 07:04PM |
Re: How fast can your smartrap print? July 01, 2014 07:33PM |
Re: How fast can your smartrap print? July 01, 2014 07:51PM |
Re: How fast can your smartrap print? July 01, 2014 08:02PM |
Re: How fast can your smartrap print? July 01, 2014 08:46PM |
Re: How fast can your smartrap print? July 01, 2014 08:53PM |
Re: How fast can your smartrap print? July 03, 2014 07:04AM |
Re: How fast can your smartrap print? July 03, 2014 08:28AM |
Re: How fast can your smartrap print? July 03, 2014 12:22PM |
Re: How fast can your smartrap print? July 03, 2014 03:07PM |
Re: How fast can your smartrap print? July 03, 2014 06:00PM |
