Re: How fast can your smartrap print? July 04, 2014 07:48AM |
duranza
Or you can do what MeIT has done and re-direct some airflow to the print
Re: How fast can your smartrap print? July 04, 2014 07:51AM |
MelT
duranza
It's just that celljeffe's fan is only 40mm so it looks like it's just big enough to blow on the cold end.
I'm having some level of success on my setup but I believe the best would be a dual fan setup. One dedicated for cold end and a ducted one for the print because as you will discover, you will need cooling only on some parts of the print. I have yet to see someone do this on smartrap though.
Re: How fast can your smartrap print? July 04, 2014 07:56AM |
Re: How fast can your smartrap print? July 04, 2014 11:49AM |
MelT
Re: How fast can your smartrap print? July 04, 2014 12:13PM |
Re: How fast can your smartrap print? July 04, 2014 06:00PM |
BackEMF
Yes i also noticed the new speed that came with the Cura 14.7 update t hought it was me overlooking some settings hehe.
In my case the higher layers now tend to crimp more (a cylinder comes out slightly conical) Am I printing to hot?
The overall result has improved a lot. Thanks Cura!
I'm going to add your Start and End codes too Reg, clever details. :-)
Is there a reason why M82 (set extruder to absolute) is removed?
I noticed that Cura this also added in the default
Re: How fast can your smartrap print? July 05, 2014 12:25AM |
CellJeffe
Hmm. I switch over to all rack-and-pinion last night (and a 0.4.9 update!) and decided to do some speed tests using the speed multiplier of Repetier (base settings Perimeters: 30mm/s, Infills: 40mm/s). Speed was not the problem. The printer could easily go 150% to 200% faster than the base settings. After some sleuthing, I determined that cooling was the main problem with increased speed!
[attachment 35891 IMG_1666.JPG]
Both of these were printed at 150% speed at the indicated temperatures. The both did quite well on the bottom layers, but as it gets to the top of the pyramid, there was just not enough time for a layer to cool before the next layer goes on. Results: slurring of the smaller layers.
I always have a fan running on my J-head to cool down the barrel. It is usually not a problem since I have mostly been printing multi-part plates with large layers. But small objects are obviously a problem. Time to think about adding more fans to cool the print as well. Any pointers to a good ducted fan design that might work well with my servoless J-head mount?
[attachment 35892 IMG_1667.JPG]
My servoless hotend
Re: How fast can your smartrap print? July 05, 2014 12:29AM |
Re: How fast can your smartrap print? July 05, 2014 09:14AM |
Re: How fast can your smartrap print? July 05, 2014 09:56AM |
regpye
Have a look at this video to give you some ideas on how a fan could be mounted on a SmartRap.
I will do some design work when I get time so it will fit mine.
Re: How fast can your smartrap print? July 05, 2014 11:35AM |
CellJeffe
Thanks, regpye, but I was well into my redesign before I saw that. I'm quite happy so far with this simple fan mount - it works well enough so far without a duct. Though I have to thank you again after stealing your ideas of the long lever arm and short bowden tube retainer for the servoless lever.
Re: How fast can your smartrap print? July 05, 2014 11:45AM |
regpye
Yes I noticed that you followed my idea and used a similar design. Works well doesn't it?
When I get it all finished I will post the files for others to use if they want.
Re: How fast can your smartrap print? July 11, 2014 04:38AM |
